Thread: po420 code? confused still though??
Results 1 to 2 of 2
  1. #1 po420 code? confused still though??
    Dec 2010
    DMV
    OK i have been throwing a 420 code for quite awhile and now i am just getting a chance to look at it properly. if i remember correctly the car has had a u bend delete done to it so what does that mean? do i change the sensor? how hard is it to replace? which sensor is it? just wanted some info guys thanks!
  2. #2 Re: po420 code? confused still though??
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    That could mean a few things.. Either the O2 sensor is bad (not reading) or your cat is dead. If your not feeling any power loss its probably not melted just not cleaning the air properly no clue how many miles you have but if its over 120k on the stock converter this could very well be the case. If you are having some powerloss you could have completely melted the cat giving you an increase in back pressure bogging you down
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  1. Random PO420 Code
    By brandonl2000 in forum General Tech Discussion
    Last Post: 12-02-2017, 11:25 PM
  2. Ok, now I'm confused.
    By Bluemagic in forum General Tech Discussion
    Last Post: 12-17-2010, 12:30 PM
  3. confused
    By danamn6677 in forum Canada
    Last Post: 12-10-2010, 06:00 PM
  4. im new and confused
    By onetyme77 in forum Introductions/Noob Questions
    Last Post: 11-28-2010, 04:03 PM
  5. 01+ po420
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2010, 05:45 PM
