Thread: All oil leaked out???
Results 1 to 13 of 13
  1. #1 All oil leaked out???
    Alabama
    As some of you already know late last week my engine started a horrible knocking sound. I went this morning and looked at it a little bit. I crunk it up and let it run at idle and tried to locate the knock. While at idle I noticed that all of the oil leaked out starting along the passenger side of the engine. I'm thinking maybe something knocked a whole in the oil pan? Is that possible?
    Black Grand Prix GT Gold Edition. headers, K&N air filter, catless exhaust, 2 Legacy Comp 15's pushed by 2500 watt Power Accoustik amp. Wish there was more but I'm baaallllin on a budget!
  2. #2 Re: All oil leaked out???
    St. Louis
    Possible, but it would be making a heck of a noise to have a rod flopping around enough to bang a hole in the pan. I would think it would lock up instead of letting it run to find the noise.
    Check around the oil filter/adapter and see if its wet. Might just be a loose oil filter. This is on the pass. side of the car where you say you saw oil leaking.
  3. #3 Re: All oil leaked out???
    Alabama
    It wasn't really a hard banging sound, it sounds more like a spray paint can rattle. It idles smooth and sometimes the knocking slowly fades away but it comes back within a minute. The oil looks like it leaked out somewhere in the region of the oil send unit.
  4. #4 Re: All oil leaked out???
    GT Level Member a3gtp's Avatar
    Feb 2009
    Salter Path, NC
    I have to ask what the fcck you're talking about with the "4:2:1" headers, you realize you have a v6 not a 4 cylinder or v8 right?
    If they catch you in the back seat trying to pick her locks they're gonna send you back to mother in a cardboard box.
  5. #5 Re: All oil leaked out???
  6. #6 Re: All oil leaked out???
    Feb 2009
    Salter Path, NC
    there, i fixed it. now you guys can shut up about it.
    Didn't mean to hurt anyone's feelings, I just wanted him to realize his error. I should've known people had already noticed it.
  7. #7 Re: All oil leaked out???
    Alabama
    A3gtp this about the headers has already been cleared up in numerous posts now but thanks for your input. I'm just trying to get some ideas of what could be wrong with my car. Thanks.
  8. #8 Re: All oil leaked out???
    Jul 2008
    sumter,south carolina
    i blew an oil filter o ring before and demolished my motor.. im guessing u did the same. any kind of internal knocking usually means the motor is ****ed.
    02 GTP with mods 05 GP for DD
  9. #9 Re: All oil leaked out???
    Alabama
    D+mn. I figured as much. Thanks for the input and if anyone has an engine for sale I'm looking.
  10. #10 Re: All oil leaked out???
    Feb 2009
    Salter Path, NC
    Make sure it's an internal engine noise before you condemn the engine, but unfortunately it sounds like you threw a rod, especially if you ran it without oil.
  11. #11 Re: All oil leaked out???
    Florida
    Yeah, the Oil filter adapter on my first motor cracked somehow, drained all my oil overnight.
    You can also check the front main seal...more difficult to damage, but that will bleed oil like a stuck pig.
    But knocking is never ever good.
    Check out ebay, you can typically find decent motors for cheapish.
    Just got me a 36k mile L26 for $275bucks.
    GL with the car
  12. #12 Re: All oil leaked out???
    Alabama
    Thanks everybody for all the helpful info. Hopefully she won't be down to long...
  13. #13 Re: All oil leaked out???
    check the sensor thats attached to the side of the oil filter housing, (oil pressure sensor) mine blew out 2 times already, and it leaks out real fast. oil will pour out of the wiring plug.
