Thread: sd header question
Results 1 to 16 of 16
  1. #1 sd header question
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Hey guys. I just bought speed daddy headers and I needed help. I already have a 3 inch dp and slp catback. Is there any way to have them installed without any welding? I saw the tog style dp and it looks like it might work but I dont know. Please help....
  2. #2 Re: sd header question
    Lounge?
    They come with a down pipe and extension tube (where cat would go) plus the part that bolts up to the catback.
  3. #3 Re: sd header question
    Orland Park, IL
    Srry. New to this. But it will bolt up to my slp exhaust?
  4. #4 Re: sd header question
    I'm just giving you a hard time. There's a slew of mechanical in the lounge today.
    Yeah, should bolt right up w/o problems. Only thing is you'd be missing a cat.
  5. #5 Re: sd header question
    Orland Park, IL
    Lol. Thanks alot. I don't have a cat anyways. Right now I'm running a 3" catless dp.
  6. #6 Re: sd header question
    It's super easy then.
  7. #7 Re: sd header question
    PS..easiest way to get the rear header in is to drop the back of the subframe 2-4 inches.
  8. #8 Re: sd header question
    Orland Park, IL
    I'm not sure on how to do that. All I know is how to pull the motor forward by taking off the dog bones.
  9. #9 Re: sd header question
    Inprocess.
  10. #10 Re: sd header question
    nvm, he fixed it
  11. #11 Re: sd header question
    Actually 01...the easiest way is not to take all that off.
    jack the car and support it via the thick edge of the body under the door frame. Put the jack in the center (use a board I like 4x4) and remove teh two back bolts of the subframe. Lower the jack 2-4 inches. Now your rear manifold will come right out and the new one will slide right in. Put two bolts in to the new one to hold it to the motor and jack the subframe back into place and put the bolts back in.
  12. #12 Re: sd header question
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Pull the engine forward, you will need to pull the egr valve and TB and bring the back header from that side around. It wont fit past the valve cover
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  13. #13 Re: sd header question
    Hagerstown,Md
    I hate droping the subframe, And doing it in a driveway is a PITA. Takes maybe 2 min to pull the EGR and TB. But to each there own
  14. #14 Re: sd header question
    And I find it more of a pain to do the EGr.. lol
    Its cool to see how each of us likes certain methods etc.
  15. #15 Re: sd header question
    Vancouver, WA
    I got mine in without removing the TB, EGR or dropping the subframe. You can get it in if you have some patience.
    Slowest 'Cooled Gen V ever
  16. #16 Re: sd header question
    Serena, IL
    Quote Originally Posted by footballplaya3k View Post
    Me too. I did remove the valve cover though. I had a leaky VC and decided it was best to replace it.
  1. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  2. header question
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 03-06-2010, 09:39 AM
  3. Question: Header stamped ID
    By mmschoch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2010, 11:28 AM
  4. down pipe and header question
    By iwinagn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2008, 10:57 PM
  5. TOG Header Question...
    By Iron Indian in forum General Tech Discussion
    Last Post: 01-09-2008, 01:00 AM
