If its N/A look on the right side of upper intake manifold, you will see the MAP sensor (black plastic) with a electrical plug. unplug wires and twist entire assembly counter clockwise to remove. Once it is out you will have an o ring and a spring, pull both out and right there is pcv valve. It sounds more difficult than it reall is.3800 Series II PCV Valve help? - GM Inside News Forum
