Thread: P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
Results 1 to 10 of 10
  1. #1 Re: P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
    So...the float is bad?
    I'd yank the pump out and see what's up there...other than that...I'm not really sure...never ran into this problem and I've had everything ELSE go wrong with my car since I've owned it.
  2. #2 Re: P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
    its not really a float.
    Circuit Description
    The fuel level sensor changes resistance based on fuel level. The PCM monitors the signal circuit of the fuel level sensor in order to determine fuel level. When the fuel tank is full, the sensor resistance is high and the PCM senses a high signal voltage. When the fuel tank is empty, the sensor resistance is low and the PCM senses a low signal voltage. The PCM uses the signal circuit of the fuel level sensor in order to calculate the total remaining fuel percent in the tank. The PCM sends the fuel level percent via the class 2 serial data circuit to the IPC in order to control the fuel gage. The fuel level information is also used for misfire and EVAP diagnostics.
  3. #3 Re: P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
    Chicago
    Circuit Description
    I do get misfire and EVAP pending codes...so maybe the WOT issue will be resolved with the pump change???
    Please say yes LOL
  4. #4 Re: P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
    its hard to say weather or not you should change the hole fuel pump or just the sending unit.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. SES Code P0101 ( MAF Sensor Low voltage)
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2010, 03:01 PM
  3. po341 cam sensor circuit code
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2009, 12:07 AM
  4. Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2009, 07:00 AM
  5. underhood relay center/ voltage to fuel circuit
    By Golgo13 in forum General Tech Discussion
    Last Post: 02-06-2009, 05:10 PM
