Thread: Fuel pump or Fuel Pump Resistor
Results 1 to 8 of 8
  1. #1 Re: Fuel pump or Fuel Pump Resistor
    Grand Rapids, MI
    sounds like it could be the CPS with the way you describe the RPM changes. RPM fluctuation is a pretty good indication.
    try the resistor tab bend thing and see if that helps. if not, maybe it is your CPS or fuel pump. any SES lights??
  2. #2 Re: Fuel pump or Fuel Pump Resistor
    SE Level Member Dragan's Avatar
    Midland, MI
    no lights are on and i will tomorrow but do i bend that prong out then start the car or do i do it when its running?
  1. Fuel Pump Resistor By Pass Mod
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2012, 05:49 AM
  2. fuel pump resistor
    By GTPgurl in forum General Tech Discussion
    Last Post: 01-07-2011, 09:19 AM
  3. Fuel Pump/Resistor issue
    By Pshnmeawy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 07:51 PM
  4. Thanks for fuel pump resistor, but with only first gear?
    By BoilerGoldGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 08:55 PM
  5. fuel pump resistor
    By gnjim in forum General Tech Discussion
    Last Post: 03-02-2009, 08:26 AM
