come on, really, anyone?
so it has stall while driving?
That issue could be a few things. Your cps sensor can cause that if its going bad.
Maybe you fuel pressure regulator is shot. Pull the vac line off it and see if gas comes out. If it does, then its bad.
Hopefully others will chime in.
To rule out the Fuel Pump Resistor...do this and that will put your pump in high speed mode. If it runs fine on this, your resistor is bad. replace it. if not, could be the fuel pump or like cam said, sensors.
hope this helps.
