Thread: Mod Suggestions For Beginers
Results 1 to 20 of 44
  1. #1 Re: Mod Suggestions For Beginers
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: Mod Suggestions For Beginers
    TDCRacing
    Guest
    I made my mistake with the 160...both posts well put indeedss
  3. #3 Re: Mod Suggestions For Beginers
    St Louis MO
    Quote Originally Posted by TDCRacing View Post
    There are still a few people running 160's. Back before the wbody group had tuners and other means of KR reduction, it was one other way of controlling knock. There are many more options now, without the negative side effects.
    As far as the SS and mods, I have first hand experience. Even with headers, DP, 104's, 180* 1.9 rockers, CAI and some small items, I could barely pull off running a 3.5 pulley. I could run nearly KR free, but had to run too rich of an AFR to quench that KR. Rich AFR= slow or slower than it should be.
    2010 Camaro SS LS3
  4. #4 Re: Mod Suggestions For Beginers
    May 2008
    LITH Illinois
    I ordered a aeroforce scan gauge to help monitor my KR. Not too sure how much I have now. I actually went to track not too long ago and actually pulled a 14.2 @ 99 mph. I will definately pick up the headers though. I also am considering the SS IC. Any recommendations for monitoring KR closer?
  5. #5 Re: Mod Suggestions For Beginers
    TDCRacing
    Guest
    May i ask what dods you had to pull that off? and That pretty much does it for monitoring kr...at lreast you have something...good investment...
  6. #6 Re: Mod Suggestions For Beginers
    St Louis MO
    Quote Originally Posted by spidamanSS View Post
    For monitoring KR the Aeroforce is a great choice. To go along with that, mod appropriately and tune with some cushion built in.
    When going with the SS IC get the best FMHE you can. If buying the kit from ZZP consider calling and having them upgrade you to this ZZ Performance
    if piecing together a SS IC kit consider this Air to Water Heat Exchanger
    2010 Camaro SS LS3
  7. #7 Re: Mod Suggestions For Beginers
    May 2008
    LITH Illinois
    Only thing I had to take out was my subwoofer (1 12inch). Thanks for the tips.
  8. #8 Re: Mod Suggestions For Beginers
    May 2008
    LITH Illinois
    sorry I also took out the spare tire.
  1. Tire Suggestions
    By Risinnfallen in forum General Tech Discussion
    Last Post: 05-27-2008, 04:11 PM
  2. Muffler suggestions
    By DanGTP in forum General Tech Discussion
    Last Post: 03-29-2008, 11:34 PM
  3. need foglight bulb suggestions
    By shaferz in forum Visual/Body Modifications
    Last Post: 02-25-2008, 07:02 PM
  4. MOD suggestions please
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 07:59 PM
  5. Buying a TV. Suggestions?
    By thermanlee in forum Off Topic Discussion
    Last Post: 01-15-2008, 03:56 AM
