Thread: burning coolant:( smokes when i shut it down
Results 1 to 11 of 11
  1. #1 burning coolant:( smokes when i shut it down
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    So I thought it was the lim but my dad says differant. I have a gt. Its leaking from the gasket on the black thing the throtle body and cai are connected to. Super nub question I feel dumb but if anyone underdstands what iim sayin and can help me out it would be greatly appreciate. Thanks guys
  2. #2 Re: burning coolant:( smokes when i shut it down
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Sounds like you are trying to say it is leaking from the Upper Intake Plenum (Black piece)....They are made of plastic and are known to warp in the area you are saying the leak it coming from. Not a very expensive replacement, maybe $75 in parts for the Upper Intake and the gasket....Clean your throttle body while you have everything apart. An honest shop would charge you an hour to an hour and a half, it really doesn't take long at all.
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  3. #3 Re: burning coolant:( smokes when i shut it down
    Donating Users
    South Deerfield, MA
    ^^^ Yes. The plastic plenum will melt around the EGR inlet on the plenum. It happened to me on my old GT and I helped someone I know with a Park Avenue that had the same problem. There is a coolant passage right around this area that gets melted by the heat from the EGR inlet and causes coolant to leak into the intake. You can buy the plenum kit with all the gaskets needed to change it from rockauto.com for about $75 iirc.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  4. #4 Re: burning coolant:( smokes when i shut it down
    Dec 2010
    plymouth ma
    Wow you guys are great. I'm gonna tackle this one myself next week. Any tips to make this easier? And I was wondering does that have some torque specs or anything special I need to do?
  5. #5 Re: burning coolant:( smokes when i shut it down
    Jul 2010
    Holyoke, MA
    It's not hard it will take you an hour and a half if it's your first time. Tips would be to remember where the two longer bolts come from (one in the front right, one in the back right if I recall) also to remove the throttle body there will be a bracket in the way preventing you from getting at the bottom bolt. Pry those out of the way, trust me it's fine that's just what you have to do, no way around it....remember where all your plugs come out of, be careful with the injector clips too. Screwdriver works but be gentle. Really not hard, fuel rails snap out after a few tugs once you remove the 4 10mm nuts that hold the rail in place
  6. #6 Re: burning coolant:( smokes when i shut it down
    Grand Rapids, MI
    we have a pick that tends to work well for the injector clips and are gentle on them. see if u can't find a little pick. ours is about the size of an ice pick just curved.
    also, go ahead and put new injector o-rings on while u have the fuel rails out.
    and if you haven't done LIM gaskets, do them now. you will thank yourself later.
  7. #7 Re: burning coolant:( smokes when i shut it down
    Jul 2008
    sumter,south carolina
    02 GTP with mods 05 GP for DD
  8. #8 Re: burning coolant:( smokes when i shut it down
    Dec 2010
    plymouth ma
    Ok so upon further inspection, it seems to me to be the lower intake gasket. I can see green on the side where they come together. Little anxious about this as I don't wanna fix in my driveway its 8 above zero and falling at 930 am. I'm sure its been gone since before I bought the car how bad is it to let go for maybe another month? My oil is fine, I'm sure its just a crack in the gasket what am I getting into with this?
  9. #9 Re: burning coolant:( smokes when i shut it down
    Jul 2008
    im doing my first LIM gasket... started yesterday but got held up due to a ****ed up valve cover... its not that bad of a job.
    watch this vid
    http://www.cpaclubgp.com/misc/lim-gasket.html
  10. #10 Re: burning coolant:( smokes when i shut it down
    SE Level Member blueGT00's Avatar
    Mason City,Iowa
    PM me and ill tell you about mine...im doing mine as we speak...takes around 2-4 hours to get everything out(being careful) and another 2-4 to put it back together if not longer.Change coolant and oil at this time.New Thermostat and a bunch of stuff...check out my thread http://www.grandprixforums.net/00-gr...g-s-41544.html
    '03 Chevy Silverado 1500 Blacked Out (My Truck)
    '00 Pontiac Grand Prix Gt (Fiancee's car)
    "you have to remember women are never wrong and they have the vagina."
  11. #11 Re: burning coolant:( smokes when i shut it down
    once you know your way around the engine it'll become much quicker.
    I installed my intercooler core and new LIM in 3 hours.
  1. My Car Is Burning Hot Lately
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-13-2010, 12:16 PM
  2. Oil Burning
    By 3rdpontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2010, 09:23 PM
  3. Burning??
    By gtp99jlp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2010, 02:48 AM
  4. Thats it, Im burning the ***** down
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2008, 08:52 AM
