Thread: air ride on a DHS N* Caddi
Results 1 to 5 of 5
  1. #1 air ride on a DHS N* Caddi
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    anyone familiar with this. i have some potential work and it seems the air shocks on the car are faulty and the computer has put a limiter on it.
    any thoughts would be appreciated
    <MiZzBeCcA>its not rape if you yell suprise
  2. #2 Re: air ride on a DHS N* Caddi
    GTP Level Member
    Pittsburgh
    the DTS uses Rear Air Shocks with Air Assist. There is an Air Compressor that is Behind the Passenger wheel that uses inputs from a level sensor that is located on the Driver controll arm. The input from the level sensor goes to the pump to tell it, to either Add or subtract air from the shocks.
    the real question, what is the car doing, is the rear of the car too low or too high??
    2003 SSEi,
  3. #3 Re: air ride on a DHS N* Caddi
    Akron Ohio
    hate Cadillacs and the air ride, there is a conversion kit to switch out the air shocks to springs I think that would be your best bet and it will never go bad again
  4. #4 Re: air ride on a DHS N* Caddi
    Jul 2010
    Las Vegas, NV
    thanks guys. the shock i put in was ok but for some reason the computer won't accept it. but for now i'm just gonna put in resistors in the car to convince the pcm that the shocks are adjusting fine.
  5. #5 Re: air ride on a DHS N* Caddi
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    Use to have an Aurora before my GP I got this week, miss the aurora but god damn are these things easy to work on....
    Anyways, which shocks did you go with?? I've heard if you get the Delco's they are really stiff.
  1. New Ride :D
    By KawaFord in forum Off Topic Discussion
    Last Post: 05-02-2010, 11:47 AM
  2. sh!tty ride
    By badbrad in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2010, 11:20 PM
  3. my ride
    By echarleswhyte in forum General Tech Discussion
    Last Post: 09-10-2009, 05:12 PM
  4. bad ride
    By badbrad in forum General Tech Discussion
    Last Post: 03-06-2009, 11:24 PM
  5. Got a New Ride.
    Last Post: 01-13-2008, 04:19 AM
