Thread: Volt and oil pressure gauge help
Results 1 to 4 of 4
  1. #1 Volt and oil pressure gauge help
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    hey i bought some gauges and i just have a couple of questions.
    For the Voltmeter gauge.... where is the best place to wire it into a 12v source? ive read that doing it directly to the battery drains it. Is that true? If so where else would be a good spot.
    And for the oil pressure gauge, where is the oil psi sending unit located in the car? Once i find it do i just unplug it then plug in my new line?
    Thanks in advance.
  2. #2 Re: Volt and oil pressure gauge help
    Charles City, IA
    Get a test light and find a wire with power when the key is on. Wire the volt into that. There is an oil pressure switch on the oil filter neck.
    SMGPFC Two Nipple General
  3. #3 Re: Volt and oil pressure gauge help
    ok thanks! il give it a shot tomorrow
    (sold) 1998 GP GT- ssm90'd. ported blower and lim, zzp fuel logs, l67 inj, 103's, zzp 2.5"dp, magnaflow mufflers, zzp plog, 3.8" ssm90 pulley, eibach springs, short db's
    2002 Z28 LS1- stock for now
    2012 chevy sonic 5spd
  4. #4 Re: Volt and oil pressure gauge help
    wrong section originally, pay attention to that, please.
    moved for you.
  1. Where to hook up oil pressure & volt gauge
    By 98GT3800 in forum General Tech Discussion
    Last Post: 02-14-2009, 10:26 PM
