Thread: Need help!!!!!!!
Results 1 to 20 of 21
  1. #1 Re: Need help!!!!!!!
    SE Level Member 86GT5SPD's Avatar
    Elkhart IN
    Quote Originally Posted by Red Devil View Post
    Double check to make sure your wire's are going to the correct plugs 1st and for most. Double check all your work and you might find your misfire issue.
    I belive the final torque spec is 11 ft pounds. I normaly just tighting them down to 15 ft pounds because that's as low as my strap-on torque wrench goes.. I've done at least 100 intake gasket jobs with no issues with increasing the final torque to 15 ft pounds.
    Start in the center and make circles outward tightening the front and rear last, then recheck tourque in any order
    9 5 1 4 8 10 6 2 3 7.
    is there any chance of cracking those plastic intake gaskets if i over torqued them just a bit? Car only ran about 20 min, but I'm guessing I'll have to buy new gaskets anyway
  2. #2 Re: Need help!!!!!!!
    Elkhart IN
    ok for anybody interested I found the problem. It's what people call the stove pipe issue. The egr tube melted a hole in the upper intake and caused antifreeze to leak into the intake and down the cylinders. I seen something suspicious in the egr port so I covered one coolant port and blew threw the other and sure enough I got air coming out of the side of the egr port. Hope this helps somebody.
  3. #3 Re: Need help!!!!!!!
    Michigain
    Quote Originally Posted by 86GT5SPD View Post
    Sorry I never got back to you, But happy to know you found the issue! That'd explain the coolant you where smelling out of the exhaust. Nice work.
    1998 Caged \ Drag GTP = Demoded & Sold
    1999 Caged \ Stattam Turboed GTP hunting for Low 10's
    2008 TrailBlazer SS AWD LS2 400 H.P
