Thread: Delete please
Results 1 to 20 of 21
  1. #1 Re: New Member Need Assistance Clicking Noise?
    Akron Ohio
    Try the plug in the heat sink behind the removable panel on the drivers side of the dashboard by the door, it should be plugged in for the DRLs to work, Unplug and see what happends.
  2. #2 Re: New Member Need Assistance Clicking Noise?
    Pull down that panel and use your finger to pinpoint which box is clicking. Once you do that, get a picture of said box and it's location. From there we can tell you exactly which module/function the box does and figure out how to replace it.
  3. #3 Re: New Member Need Assistance Clicking Noise?
    SE Level Member GTPontiacMan's Avatar
    Dec 2010
    TX
    I know where the noise is coming from. I just don't know what that plug is. I'll take a picture of it and post it. Hopefully someone will have an answer.
    The noise is definitely coming from the driver side panel next to the DRL plug.
  4. #4 Re: New Member Need Assistance Clicking Noise?
    GT Level Member donmega's Avatar
    St louis, mo
    if its a click that goes away when you use the combination switch it may be a relay. also before you start disconnecting boxes make sure its not an airbag module......Whatever you do disconnect the battery before hand just in case its an airbag module it doesnt deploy.
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  5. #5 Re: New Member Need Assistance Clicking Noise?
    Dec 2010
    TX
    Quote Originally Posted by donmega View Post
    Thanks for the heads up. I thought of that already.
  1. Clicking noise and vibration????????
    By russsellcoltwilliams in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2012, 12:56 PM
  2. Clanking/clicking noise
    By jakewet28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2010, 10:04 PM
  3. Clicking noise at start up
    By jokyfo in forum General Tech Discussion
    Last Post: 08-12-2010, 10:44 AM
  4. clicking noise inside car
    By e6600 in forum General Tech Discussion
    Last Post: 03-22-2010, 03:51 PM
  5. clicking noise
    By whitegtp in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 05:11 PM
