Thread: grinding noise.
Results 1 to 6 of 6
  1. #1 grinding noise.
    Joliet, IL
    i have a weird grinding noise coming from the front of the car....it changes in accordance with wheel rotation.....not brake related already checked that......axle or diff maybe? it takes awhile of driving for it to start almost as if it comes with heat. whatcha thinking?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: grinding noise.
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    cv axle or hub assembly would be my guess.
    i'm sure someone will chime in with the 12/6 and 3/9 stuff where you can wiggle the wheel and get an accurate diagnosis without digging in much farther, i can't remember which goes with which.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  3. #3 Re: grinding noise.
    Jul 2008
    sumter,south carolina
    id say wheel bearing... its prob heating up after driving then grinding.
    02 GTP with mods 05 GP for DD
  4. #4 Re: grinding noise.
    Joliet, IL
    forgot to mention i can only hear this noise at low speeds not high which a bearing would hum on the highway so im thinking something else.
    00 Silvermist GTP
  5. #5 Re: grinding noise.
    I live here. TLSheff's Avatar
    Quote Originally Posted by BoostJunki3 View Post
    not true, i need to replace my pass hub and it just makes noise after driving, only hear it at low speeds... had the tech at work check.... so keep it as a possibility
  6. #6 Re: grinding noise.
    Jul 2008
    I have a bad hub that I can only hear between 35-45 mph. Jack up the car and see if u have any play in the wheels
  1. 04 gt grinding noise right front
    By pmusial in forum Introductions/Noob Questions
    Last Post: 09-15-2010, 07:20 PM
  2. grinding noise on turn
    By wade722 in forum Brakes/Suspension/Chassis
    Last Post: 08-26-2010, 06:15 PM
  3. new grinding noise
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 08:07 AM
  4. Grinding noise when driving around
    By littlerobinson75 in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2010, 10:34 AM
  5. grinding noise in reverse
    By wrathofthunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 08:24 PM
