Thread: wanting to install SLP Rocker arms and pushrods
Results 1 to 7 of 7
  1. #1 Re: wanting to install SLP Rocker arms and pushrods
    Your choice is either high ratio rockers...OR a cam. I'm assuming since your getting SLP's that they are 1.80:1 Ratio. If you want you could put in a cam...BUT...you'll need a pretty beefy valvetrain as the lift will be pretty high with that rockers ratio. Things I recommened you get with the install...
    A small bottle of RTV to put on the corners of the Valve Cover Gaskets for re-install
    New Valve Cover Gaskets WITH new grommets
    Comp Cams Re-Usable Rocker Bolts
    Red Thead Locker...just a dab on the rocker bolts...because sometimes, they like to come loose...EVEN if torqued correctly and cleaned right the first time.
    Brake Clean and Q-Tips...after you remove the stock rockers...blast all that build up out if there is any.
  2. #2 Re: wanting to install SLP Rocker arms and pushrods
    GT Level Member donmega's Avatar
    St louis, mo
    I was going to go for valve cover gstks anyways since i was in there and dont know what there condition is having 160k. What about valve springs, can i keep it stock? I dont really want to go for the cam at the moment. what kind of gains will I see? where in MO are you BlueGTP? St charles here
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  1. rocker arms cam help
    By wking2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-13-2010, 04:39 PM
  2. Rocker Arms
    By stlmo_gtp in forum PCM Tuning
    Last Post: 10-01-2009, 11:08 PM
  3. 1.9 Rocker arms
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 03:07 PM
