Thread: water pump UD pulley
Results 1 to 20 of 30
  1. #1 water pump UD pulley
    Joliet, IL
    is it worth it? have one? like it?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: water pump UD pulley
    i dont think underdriving the water pump is ever a good idea.
  3. #3 Re: water pump UD pulley
    GT Level Member neel2008's Avatar
    Huntington, IN
    get an electric water pump if you are worried about it that much....then get an ac bypass pulley and rip all ur ac crap out, that will help more than silly UD pulleys
    97gtp
  4. #4 Re: water pump UD pulley
    Charles City, IA
    Buy an electric pump. I would never undrive my cooling system.
    SMGPFC Two Nipple General
  5. #5 Re: water pump UD pulley
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    It depends on your desired outcome. An electric water pump (EWP from here on) can use less engine power compared to a crank-driven pump. The reason the electric pump is able to do this is because it can operate off of the battery (essentially a power reserve). This is advantageous for heavy accelerating, where the engine is temporarily relieved of "water pumping duty" by using the battery power.
    It should be noted that an EWP should decrease your MPG because of the inherent energy conversion process. You are converting mechanical power from the crankshaft into electric potential at the generator and back to mechanical power at the EWP. No energy conversion will be 100% efficient, so there are energy losses. In real-world situations, I suspect that the difference in MPG will be negligable between the two pumps.
    Of course there are other factors to consider such as whether the electric pump can shutdown when water circulation is not needed. Also, the actual pump (not motor) has an efficiency rating that may be greater or less than the stock unit.
    Why do I make such a detailed stink about everything? I'm a mechanical engineer.
  6. #6 Re: water pump UD pulley
    Quote Originally Posted by mechguy View Post
    No...
    It runs off of your alternator.
    Again, alternator power. Not battery.
    The alternator spins regardless.
    They're 50% efficient.
    But the pump draws 6-7 amps according to manu.
    Thats 100 W.
    Thats 0.26 HP draw from the engine.
    ZZP claims it frees up 7 hp.
    And not an electrical engineer.
  7. #7 Re: water pump UD pulley
    Dec 2010
    Canada
    No...
    Thats 100 W.
    Please try to read my posts a little more carefully.
    Notice that I said "depends on your desired outcome" followed with "can use less power compared to a crank-driven pump...."
    Clearly, I was stating this in the most general sense; disconnect your alternator when racing. That's why I called the battery a power reserve. I once drove my Olds Alero for over 50km without knowing that I had a broken serpentine belt (no alternator charging). The car did not stop until I turned off the ignition at my destination. That aside, disconnecting the alternator is something I will never do, for many reasons, but I will re-iterate that the aforementioned quote was clearly in the most general sense.
    Your response of "The alternator spins regardless" is an interesting one. Very obviously, the energy conversion process I talk about is occurring. Again, you will want to notice some of my wording: "...an EWP should decrease your MPG..."
    Nowhere do I give quantitative reference, simply qualitative.
    You go on to mention some numbers and statistics which I don't care about because I was only providing theory between the two types of pumps. What the manufacturer claims is their claim and real-world testing sometimes provides unexpected results. Notice that I mention "real-world situations" in my second paragraph.
    There are many reasons why ZZP claims that the stock WP is using almost 7 HP more than the electric version. Removing the the stock WP deletes one pulley and the associated friction, bearing losses, windage, etc. Also, how do the maximum flow rates compare....and there are many more reasons. The main point is that the theory I have provided is correct.
    Again, read my posts more carefully.
    Awaiting your response....
  8. #8 Re: water pump UD pulley
    I read your post carefully...and if your going to debate something...you NEED numbers and statistics...saying you don't care means just that...you lost.
    Done.
  9. #9 Re: water pump UD pulley
    Dec 2010
    Canada
    Done.
    Nice try. I gave you 100% correct theory about these pumps. If you cannot comprehend that's fine.
  10. #10 Re: water pump UD pulley
    You'll run through batteries quite quickly. Generally the battery light comes on with the alt fails.
    In a nice short summary:
    The power being used by the water pump pulley appears to be greater than the already existent load created by the alternator which is also more than sufficient to power an electric pump.
    I never said thermodynamics were wrong.
    Nor does my napkin math suggest it.
    It merely suggests you'd find similar or improved fuel economy by utilizing the wasted power that the alternator is drawing as well as reducing the mechanical load on the crank thus the engine itself by removing the mechanical water pump.
    I see you're trying to take a fine line here and stick to your precise wording.
    But whats interesting to note is your emphasis.
    Note this section here:
    Its on the decrease which implies you are assuming that logic says the decrease is more likely.
    But..... The logic is this:
    The alternator provides a load on the engine. Full load on the engine is 4 HP. (105 A output at 14.4 V, 50% efficiency)
    The WP does the same. Full load is 7 HP (Debatable, but still >0.26 HP)
    Remove the WP entirely and add a .26 HP additional load via the alternator.
    Even if an EWP is only good for a single HP you've minimized losses.
    And to the guy who suggested hammer time..... You don't ban people who you dont agree with. That's childish.
  11. #11 Re: water pump UD pulley
    Joliet, IL
    /thread
    00 Silvermist GTP
  12. #12 Re: water pump UD pulley
    Huntington, IN
    ur waterpump is always running when ur car is running.....i would assume you would just run a thermostat like a motor driven pump....If you like to drag race, I would rather run an electric pump money permitting.
    97gtp
  13. #13 Re: water pump UD pulley
    Charles City, IA
    The alternator has the same drag no matter how much it is charging on theses cars. So adding more electrical load will not put more load on the engine.
  14. #14 Re: water pump UD pulley
    Dec 2010
    Canada
    No offense intended, but I would be happy to explain the fundamentals of this concept if you wish.
  15. #15 Re: water pump UD pulley
    May 2008
    staten island,NY
    ive had mine from zzp on my car for 5 years now. it runs cool, never had an overheating issue. the stock pulley weighs a lot compared to the zzp one so less rotating mass is good i guess.
  16. #16 Re: water pump UD pulley
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    Changed mine to ZZP's UD pulley, temps stay right near 180 still, the difference in weight is about a lb, but alot of that is in the middle where moment of inertia is changed the least. Over the next 3 tanks I noticed a .2 mpg increase, which is within the realm of being statistically insignificant, but I can see how it would be a real change.
    But for 30 bucks used on CGP I have to say I think it was worth it.
  17. #17 Re: water pump UD pulley
    Huntington, IN
    yea when I do an alternator test, you can deff hear the difference in the motor when the tester puts a load on the alt.....
    97gtp
  18. #18 Re: water pump UD pulley
    Huntington, IN
    engineers are worse.......cause they think they know everything.....lol which we have just seen here....
    97gtp
  19. #19 Re: water pump UD pulley
  20. #20 Re: water pump UD pulley
    im an engineer. i do know everything.
    Proven.
    4 times.
    3 times here...once when God told him he was a liar.
  1. Water Pump
    By carl06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 07:58 AM
  2. Water Pump
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 10:19 PM
  3. water pump
    By Ramondo411 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2009, 12:35 AM
