Thread: PCM
Results 1 to 11 of 11
  1. #1 PCM
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    i was just curious if there is any way to tell if the pcm isnt stock, i got my gtp about a month ago and from what i can tell its got u bend and res delete and i measured it tonight and it looks like a 3.4 but im not 100% because it looks just like a stock pulley
  2. #2 Re: PCM
    measure it................
  3. #3 Re: PCM
    Charles City, IA
    Do your fans stay on after you shut the car off?
    SMGPFC Two Nipple General
  4. #4 Re: PCM
    Jun 2010
    Beloit, WI
    nope not when turned off but i did notice they do turn on around 180
    and i did measure it on the outside edge it was 3.5 so that was my guess that it was a 3.4 it just looks completely stock, and idk if it matters but performance shift on it doesnt seem like it makes any difference to me
  5. #5 Re: PCM
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Quote Originally Posted by shawnschuldt View Post
    You are correct. I believe the pullies are rated for diameter where the belt rides, not the overall diameter. So if you measured an overall dia of 3.5" it sounds probobable that it is referred to as a 3.4" pulley.
  6. #6 Re: PCM
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    some companys put a sticker on them saying what Tune it has. When I was doing canned tunes my ZZP pcm came back with ZZP 1.0 SS sticker on it
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  7. #7 Re: PCM
    Jun 2010
    Beloit, WI
    yea ill have to pull it out and see if its got anything on it, its tough trying to figure out what someone has already done to it
  8. #8 Re: PCM
  9. #9 Re: PCM
    Jersey
    assume they havent done anything and redo most of it.
    that's good advise
    16' wrx sti- stock
  10. #10 Re: PCM
    Don't buy modded cars.
  11. #11 Re: PCM
    GT Level Member Mitchstrp's Avatar
    Missouri
    damn i was really considering buying your car... DAMN!
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
pcm
