Thread: air comming out of all vents
Results 1 to 8 of 8
  1. #1 air comming out of all vents
    Jersey
    The car is a 97, digital hvac controls. It doesn't matter how i have the air set, air comes out of all vents at all times. I tried replacing the drivers side actuator door, that didn't help. Sometimes the dual zone button will come on by itself. Any ideas?
    -Erik
    16' wrx sti- stock
  2. #2 Re: air comming out of all vents
    Charles City, IA
    Check for vacuum at the hvac control module.
    SMGPFC Two Nipple General
  3. #3 Re: air comming out of all vents
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    Quote Originally Posted by 99prixgt View Post
    ive never played with a digital hvac, but i didnt think that the digital would have vacuum controlled blend doors....
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  4. #4 Re: air comming out of all vents
    Oct 2008
    Calgary, Alberta
    My 98 has the dual digital climate controls, and it converts it over for vacumme operation. on the other hand my 1988 Pontiac Fiero had push button electronic mode selector, and a slider for the temperature that i was abl;e to convert to use the digital controller from the late 90's Grand Prix, rigged up as single zone.
  5. #5 Re: air comming out of all vents
    Dec 2010
    WI
    Where is this hose located?
  6. #6 Re: air comming out of all vents
    Oct 2008
    Calgary, Alberta
    on my 98gtp the hose runs through the wiring harness by the battery and fuse block on the passangers side, into the car in the middle by the front of the console, one of the only balck lines going to the hvac controller with a black boot. I replaced mine with a piece of brake line following the automatic shifter on an 98 gtp (supercharged) reducing the vacume line length by at least 1/2.
  7. #7 Re: air comming out of all vents
    Willoughby, Ohio
    kinda sounds like the control module itself, if buttons/modes are enguaging by themselves
  8. #8 Re: air comming out of all vents
    Ocala, FL
    How much air?.. If its slight, try turning it to max and see if it keeps blowing. If thats the case it's normal.
  1. SES light not comming up after CAT delete.
    By Juanmiguel in forum General Tech Discussion
    Last Post: 05-12-2010, 11:03 AM
  2. So umm. when is the chat comming back??
    By 16MustangVet in forum Forum Bugs/Suggestions
    Last Post: 02-11-2010, 01:37 PM
  3. thumping noise comming from front end.
    By need2know29340 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-29-2009, 11:06 PM
  4. got a race comming up
    By blowfishRus6 in forum Track Sessions and Kills
    Last Post: 12-10-2008, 10:06 PM
