Thread: machined lim or not
Results 1 to 11 of 11
  1. #1 machined lim or not
    SE Level Member spina74's Avatar
    blackwood
    I'm getting ready to install a ported m90 and I have a spare lim. The car more than likely will not be intercooled. I am not sure if I should open up the lim or not. If so does anyone have a write up on how to because I can't find one
  2. #2 Re: machined lim or not
    Omaha, NE
    Gen 3 yes, Gen V no.
  3. #3 Re: machined lim or not
    You could, but its kinda a waste of effort.
    Unless the H bridge has already been removed.
  4. #4 Re: machined lim or not
    Florida
    Im in the same boat..already got the H bar removed, and the inlet is also ported (Gen 3) I want to just open up inlet on the LIM...
    Looked around on the forums, havent seen any write-ups, or templates...so any pointers would be great.
  5. #5 Re: machined lim or not
    take your stock gasket and cut out the inside of the centre red/orange line and then drop the gasket on the LIM then take a sharpie to it so you know what to cut.
    remove gasket and cut.
    Thats all I did when i opened up mine for the intercooler.
    Pictures shortly.
  6. #6 Re: machined lim or not
    Florida
    Alright, thanks....
    didnt even think of that...even tho that's the easiest way....
    Pics would be great too, thanks matt
  7. #7 Re: machined lim or not
    As promised:
    I'm running an intercooler that requires that particular gasket hence the extra hole for the rear head PCV.
  8. #8 Re: machined lim or not
    Florida
    Ty sir, give me a little project to do once im back in state.
  9. #9 Re: machined lim or not
    blackwood
    I keep reading about the hbar what exactly is that
  10. #10 Re: machined lim or not
    Florida
    Sorry for the crappy picture links, but I dont have any pics of mine before/after..
    Theres a bar going across the Outlet of the supercharger, limiting the size of the outlet.
    http://t0.gstatic.com/images?q=tbn:A...XXn0Bn0e4j&t=1
    see the bar going across the middle of the supercharger...that the H bar.
    Now, when you port the outlet, you also typically remove the H bar...here it is without the H bar.
    http://www.zzperformance.com/products_img/162_1.jpg
  11. #11 Re: machined lim or not
    You only remove the H Bar when you intercool your car...otherwise it doesn't matter.
    Plus...a ported LIM does nothing unless like I said...you have an IC or ported heads to match the ported runners.
  1. Machined intake???
    By funky4stringed in forum General Tech Discussion
    Last Post: 07-05-2010, 10:54 AM
