Thread: keys dont work for trunk and backseat split door?
Results 1 to 19 of 19
  1. #1 keys dont work for trunk and backseat split door?
    Dec 2010
    DMV
    hey is there a way for me to get a key that opens the trunk and the lil door in the seat without costing me an arm and a leg? my keys just opens the door and starts the car
  2. #2 Re: keys dont work for trunk and backseat split door?
    GT Level Member neel2008's Avatar
    Huntington, IN
    junkyard is my vote, find a gp, grab a key and the locks for the trunk and ski hole cover thing.....
    97gtp
  3. #3 Re: keys dont work for trunk and backseat split door?
    Akron Ohio
    I lock place can change that for you
  4. #4 Re: keys dont work for trunk and backseat split door?
    Topeka, KS
    Your ignition cyl./tumbler whatever you want to call it could have been changed since the car was built. If so just go to the dealership and have them make you a key off your vin. The original key should open the trunk and pass through.
  5. #5 Re: keys dont work for trunk and backseat split door?
    swift current,sask.
    You got a valet key then, that's what it's supposed to do. Won't open the glove box either right?
  6. #6 Re: keys dont work for trunk and backseat split door?
    Topeka, KS
    ^^Probably not.
    Depending on your year of car the keys for 97-99 are like 30 bux and 90ish for the 2000+ due to the PK3 system chip being in your key. If your dealership knows you they usually won't charge that much though.
  7. #7 Re: keys dont work for trunk and backseat split door?
    can u even get into the trunk? if so it should be just a C clip holding the lock in place, remove and buy a new lock and key.
    i have a regal and the door in the seat is locked by a metal lever that turns with the key so unscrew the latch ( lever) and remove that lock too.
    it sounds like that last owner had the door locks replaced. and failed to give you the old key to the trunk.
    last time i replace door locks they sere like 10 or 20 bucks, new.
  8. #8 Re: keys dont work for trunk and backseat split door?
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by whiney View Post
    best answer yet. is teh key grey or black?
    02 GTP with mods 05 GP for DD
  9. #9 Re: keys dont work for trunk and backseat split door?
    GT Level Member 2000GrandPrixGT2000's Avatar
    Trevose, PA
    I'd guess grey since my valet key is grey and says valet right on it
  10. #10 Re: keys dont work for trunk and backseat split door?
    Huntington, IN
    hmmm i dont have a valet key....interesting....
    97gtp
  11. #11 Re: keys dont work for trunk and backseat split door?
    then its prolly a copy of the valet key
  12. #12 Re: keys dont work for trunk and backseat split door?
    I live here. TLSheff's Avatar
    The only difference 97-99 is the standard "master" key has a black plastic head, the valet is just smooth metal, thin, fits well in my wallet
    Not sure on 2000+ with PK3 but Id imagine theres little difference on the keys in that range.
    As for dealerships doing it, if they follow GMs new rules on key cuts you HAVE to take the Title, or Registration from Tag Office and your Drivers License to prove ownership. Too many people cheating the system so they got really strict 2 months ago. Will not pull the key codes without the proper documentation
  13. #13 Re: keys dont work for trunk and backseat split door?
    GT Level Member GrandPrixSE's Avatar
    Jun 2010
    Indy
    hmmm only key I got with my car was a solid gold metal one, that unlocks the doors and starts the car, but won't work on the glove box or truck or that passage way thing...
    hmmm....
    2000 Buick LeSabre Custom - 3800 Series II V6
    1998 Buick LeSabre Custom - 3800 Series II V6 ​SOLD!
  14. #14 Re: keys dont work for trunk and backseat split door?
    Dec 2010
    DMV
    Ok thanks you guys, I have a silver key and a identical one that has a black cover over the top. The plain silver one is the one that opens the door and starts the car. So I'm guessing im going to have to hit a dealership to get the right ones huh?
  15. #15 Re: keys dont work for trunk and backseat split door?
    Nova Scotia
    does the identical black one work anything or just the same as the "silver" one?
  16. #16 Re: keys dont work for trunk and backseat split door?
    Dec 2010
    DMV
    The black one doesn't work for anything, I'm not even sure why I have it lol
  17. #17 Re: keys dont work for trunk and backseat split door?
    Jul 2008
    as said in above post... take your registration to dealer and they will cut u the right key using your VIN.
  18. #18 Re: keys dont work for trunk and backseat split door?
    Grand Rapids, MI
    yeah it sounds like you have a valet key, though it may look like the master key having all the GM rubber coating on it. my valet key is DARK black and my master key is smoky gray.
    i hope that helps you some.
  19. #19 Re: keys dont work for trunk and backseat split door?
    I just have two PK3 keys that do everything?
  1. Removing the backseat/trunk door
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-03-2010, 09:06 PM
  2. Wiper dont work at all
    By Lentrave in forum General Tech Discussion
    Last Post: 05-23-2010, 03:21 PM
  3. HELP headlights dont work... period
    By daveydavido in forum General Tech Discussion
    Last Post: 02-24-2010, 06:48 PM
  4. defogger dont work
    By beckys2000gt in forum General Tech Discussion
    Last Post: 11-30-2009, 11:11 AM
  5. Trac and ABS dont work!?!?
    By 99gpse in forum General Tech Discussion
    Last Post: 01-01-2009, 01:26 PM
