You need a code reader that can read codes from the ABS module. Most standard code readers can't do this. So you need a dealer/brake shop to tell you the code.
That will tell you what wheel to look at. Then you can look at the wiring/connectors. If those are good then it's a problem with the sensor in the hub itself.
