I had a similar problem happen with a car I had in the past. It turned out to be a bad contact on the starter. Check to make sure the ground is good and the connections are tight and clean.
Thanks Silver GTP, checked the connections, they were clean, but I installed a new starter and that seems to have it fixed, I think the solenoid was intermittant. The starter had a million cranks on it (I use the car at work sometims - shut off and restarted ALOT).
