Thread: heat problems
Results 1 to 9 of 9
  1. #1 heat problems
    Feb 2010
    united states
    i was wondering if any one else has this problem. when it gets hot outside my car will turn my abs and traction control off. then it says service traction system and service other things. i was wondering if anyone has this or knwo what is causing it. it will go off when i restart my car.
  2. #2 Re: heat problems
    your abs sensors are going?
  3. #3 Re: heat problems
    Feb 2010
    united states
    why does it only happen in summer when it hot
  4. #4 Re: heat problems
    That I could not tell you.
    Curious why you waited this long to ask this question as well.
  5. #5 Re: heat problems
    Feb 2010
    united states
    well it happens every summer and no mecanics know what it is, they all say it isnt hurting the car but its geting anoying
  6. #6 Re: heat problems
    next time the light comes on get the ABS code read and see whats up.
    It could be that when the sensors heat up the resistance goes above the tolerance for throwing a code but when the temp comes back down the resistance falls back into the proper range.
    Just have to catch it when its causing the code and find out which one it is.
  7. #7 Re: heat problems
    Feb 2010
    united states
    it dosent throw any codes tho. i thought it could be the cpu
  8. #8 Re: heat problems
    when your ABS light is on there is a code to be read.
    But you need an ABS capable scanner to see it.
    Tech II scanner would be ideal, but only the stealership has those for the most part.
  9. #9 Re: heat problems
    Akron Ohio
    If you live close to me I can scan.
  1. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  2. heater problems/no heat
    By cartkid14 in forum General Tech Discussion
    Last Post: 12-23-2008, 06:11 AM
  3. heater problems/no heat
    Last Post: 12-22-2008, 11:22 PM
  4. '05 Prix Heat Problems
    By Breezy in forum General Tech Discussion
    Last Post: 12-11-2008, 10:09 AM
  5. Air and heat problems
    By chrizzle17 in forum General Tech Discussion
    Last Post: 12-10-2008, 08:28 PM
