Thread: Heater not working properly
Results 1 to 8 of 8
  1. #1 Heater not working properly
    Farmington, NM
    I have a 2006 Grand Prix Base and have recently noticed that the heater goes in and out of blowing heat. Sometimes it takes a long while for any heat to come out. It's cold outside nowadays and it's not comfortable driving when it's chilly in the car.
    Anybody know what's going on and what I can do to fix the problem?
  2. #2 Re: Heater not working properly
    Akron Ohio
    Do you have heat then it goes away, Does it come back?
  3. #3 Re: Heater not working properly
    Farmington, NM
    Sometimes the heat comes on right after turning on the car. Sometimes it blows cool air then starts blowing warm air, not warm enough. When the heat does come on it's for awhile then the cool air will start blowing again.
  4. #4 Re: Heater not working properly
    Akron Ohio
    Have you done anthing with the coolant, changed a hose ect.
  5. #5 Re: Heater not working properly
    Farmington, NM
    I got the radiator flushed not too long ago and changed the thermostat as well
  6. #6 Re: Heater not working properly
    Akron Ohio
    Funny how I guessed that lol. you have a bubble in the coolant on top of the coolant neck should be a screw you need to bleed it when you car is at normal temp.
  7. #7 Re: Heater not working properly
    Farmington, NM
    And how do I do that? Is it simple?
  8. #8 Re: Heater not working properly
    Topeka, KS
    Whats your coolant temps like ? Your thermostat could be stuck open.
  1. Troubleshooting Help? DIC & heater/AC not working
    By TMC in forum General Tech Discussion
    Last Post: 12-12-2010, 02:30 AM
  2. Rear brakes not working properly
    By mjkoester in forum Brakes/Suspension/Chassis
    Last Post: 05-21-2010, 09:31 AM
  3. What to check if your system isn't working properly
    By matt5112 in forum Audio, Security & Visual Electronics
    Last Post: 12-04-2009, 09:45 PM
  4. Lights on heater knob-shifter coilumn not working
    By wildcat99 in forum Audio, Security & Visual Electronics
    Last Post: 07-30-2009, 09:13 PM
