Quote Originally Posted by killer84 View Post
i knew the compression diffrence thats y ya switch the heads the bottom ends the same on gt and gtp i hear idk just what i heard not doin the swap till summer tho so yeah im doin my research i just knew the gen v setup was better
Bottom ends ARE NOT the same.
Pistons and rods are both different. GT block has higher compression...GTP block has lower compression...I don't think your understanding that switching the heads does nothing for compression ratio. Switching the heads allows for the injector embosses to be in the heads and not in the lower intake manifold like on your N/A car...
