Thread: OBDII scanner/tool recommendations
Results 1 to 13 of 13
  1. #1 Re: OBDII scanner/tool recommendations
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    If you could find a LS1M used(they no longer produce them) that would be the best bang for the buck, as it scans and logs. It would work on any 3800 or ls1 vehicle.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  2. #2 Re: OBDII scanner/tool recommendations
    Check out this GM Enhanced Software . It run great with this obd2 scanner.
    I've been using it for 2 years and you can read ABS, SRS and special powertrain codes.
  1. OBDII Codes [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-26-2011, 01:23 AM
  2. Obdii?
    By Viper in forum General Tech Discussion
    Last Post: 03-06-2010, 09:58 AM
  3. ECM To OBDII Connection
    By lstexan in forum General Tech Discussion
    Last Post: 02-07-2010, 03:05 PM
  4. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
