Thread: Emissions test FAIL--Hydrocarbons Maximus!
Results 1 to 5 of 5
  1. #1 Emissions test FAIL--Hydrocarbons Maximus!
    Mesa, Arizona
    Looks like I have some kind of air leak. Car idles at nearly twice rpm it should. I believe computer is trying to compensate for the increased air being leaked into the combustion system. Gas mileage has sharply decreased in recent months and there has been a loss of power. "Service Engine Soon" light comes on periodically
    Went through emissions last week and my hydrocarbon reading was almost 3 times the limit. Two years ago when I went through emissions that reading was about 1/4 of the limit.
    The other two readings, Carbon Monoxide and Oxides of Nitrogen passed although the CO reading was near the limit. Here are the results of the test
    HYDROCARBONS-------My vehicle - 2.36 / Standard .80----FAIL
    CARBON MONOXIDE----My vehicle -10.62 / Standard 12.00--PASS
    OXIDES OF NITROGEN--My vehicle - .61 / Standard 2.00--- PASS
    Mechanic friend thinks there may be an air leak through the plenum (upper intake manifold) gasket? Could it be the lower intake manifold gasket?
  2. #2 Re: Emissions test FAIL--Hydrocarbons Maximus!
    St. Louis
    Could be. Could also be a vac. leak. Spray carb cleaner all around the intakes, and at all vac. fittings while the engine is running and see if you find a spot that makes the idle/sound of the motor change. If you find one, then that's the issue.
    See if you can scan for codes to find out what the CEL is coming on for. Should point you in the right direction. Even if it's out it should be stored in memory I would think.
    Jay
  3. #3 Re: Emissions test FAIL--Hydrocarbons Maximus!
    Charles City, IA
    Yeah sounds like a vac leak, I bet your upper plenum is wraped/ cracked.
    SMGPFC Two Nipple General
  4. #4 Re: Emissions test FAIL--Hydrocarbons Maximus!
    Mesa, Arizona
    Thanks for the help
  5. #5 Re: Emissions test FAIL--Hydrocarbons Maximus!
    Mesa, Arizona
    ok.
  1. Failed Emissions Test
    By Biohazed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2013, 09:24 AM
  2. Maximus beltmus wrapis
    By 2003 SSEi in forum Visual/Body Modifications
    Last Post: 11-28-2010, 06:13 PM
  3. Oh, Emissions...
    By smcglaug18 in forum The Rant Forum
    Last Post: 08-17-2010, 08:51 AM
  4. E-Test Fail - Next Steps
    By toolmanz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-17-2009, 09:47 PM
  5. emissions
    Last Post: 02-22-2009, 11:56 PM
