Thread: 99 GTP DIC issue, and cant read SES light
Results 1 to 9 of 9
  1. #1 99 GTP DIC issue, and cant read SES light
    SE Level Member LSXHP's Avatar
    Morris IL
    Cars been doing this for a while and I cant figure it out. The DIC (Drivers Information Center) is flashing 0.0 for everything and not showing any boost on the screen. Also the TCS off light stays on and I cannot turn tcs back on to shut off the light. It starts flashing a few seconds after I start the car or move it. Also the SES light is on but I cannot get any scanner to read it from the adl port. Scanner just says no signal detected or whatever as if the key were off. I think the SES light is on because of a missing cat and a bigger down pipe in its place but anything else i cant tell now. Car runs fine though. This started as a random issue and just happened more and more often not its every day every time. ANY ideas? Ive posted about this issue before but nobody could help. Anyone???
    White 99 GTP-180*,FWI,ZZP Plog,3"DP.ZZP PCM, Magnaflow resinator.
    SOLD June 2009 Silver 2000 Z-28 383LSX Stroker, 10.94@122 N/A
    2004 Suzuki GSXR-750, lowered, Piped,filters,smoked screen
  2. #2 Re: 99 GTP DIC issue, and cant read SES light
    Charles City, IA
    sounds like you need a new pcm, flashing zeros on the dic indicate it is in programing mode.
    SMGPFC Two Nipple General
  3. #3 Re: 99 GTP DIC issue, and cant read SES light
    Morris IL
    That's one thought I had too, someone else said maybe the DIC itself is bad but how would I be able to tell which it is? Would either of these be the reason I can't scan it to see what the ses light is on for?
  4. #4 Re: 99 GTP DIC issue, and cant read SES light
    Morris IL
    Also the scanner is getting power from the port under the dash too, it just acts like the key isnt in the "ON" position, so its not a power issue or a fuse either.
  5. #5 Re: 99 GTP DIC issue, and cant read SES light
    Charles City, IA
    Some grand prix dont have power at the aldl port, mine doesnt. Yeah a bad pcm could keep you from reading the codes.
  6. #6 Re: 99 GTP DIC issue, and cant read SES light
    Morris IL
    But if the aldl port wasn't getting power the scanner wouldn't turn on. It just reads no data as if the key were off. Any way to test a pcm?
  7. #7 Re: 99 GTP DIC issue, and cant read SES light
    Morris IL
    Somebody on a different forum suggested a wheel speed sensor as possble culprit for the flashing dic. Now that I think about it back when the issude first started it would stay normal when I started the car then start blinking once I moved the car...what do you guys think, is he onto something? Where is this sensor located?
  8. #8 Re: 99 GTP DIC issue, and cant read SES light
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    does the car start? i am having a similar issue but mine cranks not start. dic flashing 0.0 w/o anything plugged into the obd2 port. i think pcms bad. did you ever fix this?
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  9. #9 Re: 99 GTP DIC issue, and cant read SES light
    Morris IL
    Replaced the pcm with one from ZZP and it fixed everything.
  1. temp light issue
    By disblile in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-04-2016, 12:55 PM
  2. Right Running Light Issue
    By mlasnoski in forum General Tech Discussion
    Last Post: 09-30-2010, 10:21 PM
  3. Temp Light Wiring Issue???
    By disblile in forum General Tech Discussion
    Last Post: 06-29-2010, 05:26 PM
  4. Temp light wiring issue??
    Last Post: 06-28-2010, 10:22 AM
  5. ABS & Tracion control light problem.. PLEASE READ
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2009, 08:52 AM
