Thread: sludge in coolant
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
  1. #1 sludge in coolant
    Dec 2010
    Minnesota
    Hello,
    You guys have helped me tremendously from previous threads I have read and I have a recent issue with my 99 GTP I wanted your advice on. My car runs great, but I noticed alot of brown sludge stuck to the walls of the fill tube as I opened my radiator cap last night. I also noticed a brown/orange film on the walls of the plastic fill reservoir. My low coolant light came on last week (first time after 193,000 miles), so I put in some Prestone and it went away.
    Does this sound like a major problem? Could it be related to Dexcool? Ive never flushed the cooling system, but I will after this. What do you guys think casued this sludge?
    Thanks,
    Gobux
  2. #2 Re: sludge in coolant
    Get RID of the dexcool. Yes, its causing the sludge...commonly known as Dexsludge. Replace it with normal yellow or green stuff.
    Probably will want new hoses, T-Stat, and intake gaskets done at the time too. Because the dexcool just eats away at it all.
  3. #3 Re: sludge in coolant
    Nov 2009
    Grand haven
    THIS^^^
  4. #4 Re: sludge in coolant
    Donating Users NoBoost91's Avatar
    Queens, New York
    I had the same problem so I Removed the drain plug and knock sensor and flushed the system about 3 months ago, but I put that dexcool garbage back in :/ , and now my water pump is going bad so now I'll remember not to use it again
  5. #5 Re: sludge in coolant
    Arizona
    just had mine flushed because of that.
    apparently its caused from mixing dex and the other antifreeze stuff
    '00 GT- nothing special
  6. #6 Re: sludge in coolant
    dex + ethylene glycol will sludge.
    dex + air will sludge.
    If you maintain the system well you wont have any issues with dex.
  7. #7 Re: sludge in coolant
    Thanks Matt...
    I wouldn't have said it quite as well.
  8. #8 Re: sludge in coolant
    Pennsylvania
    Read this. http://www.grandprixforums.net/dexco...ing-36656.html
    I've found that keeping it all kinds of full is a good band-aid for the coolant's health until you can actually fix the problem by installing new aluminum lower intake manifold gaskets. But your coolant will still get into your oil, regardless of what color it is. Change the gaskets, flush the coolant, refill with dex, sleep soundly knowing that you've got a permanently fixed, healthy car.
  9. #9 Re: sludge in coolant
    Quote Originally Posted by SlowNA06 View Post
    http://www.grandprixforums.net/pitti...rts-38940.html
    went from no coolant leak to having to do that repair.
    And thats your godly green stuff.
  10. #10 Re: sludge in coolant
    I've seen the gaskets in Series 1 motors as well as 2 and 3 motors look like hell. Some of those had green, some dex and some of the newer dex. All in all the plastic gaskets have issues and it seems to be more heat related than coolant related.
    Plus..if we are saying the coolant causes the aluminum to corrod, then wouldn't we be contradicting ourselves a little if we then suggested putting aluminum frame gaskets in the motor to correct the problem?
    Coolant system maintenance and the aluminum gaskets has seemed to solve the issue in all the vehicles I work on. As for the pitting, nice fix.
  11. #11 Re: sludge in coolant
    Dec 2010
    ky
    ive talked to 3 different radiator shops and they all said the same thing.get rid of the dex and put in the green.dexcool becomes corrosive after 4 or 5 years and ive seen it first hand eat the fins off of a water pump.the shops told me its the worst thing you can put in ur car and im not just talking gasgets its bad for everything,waterpumps,radiators,heater cores,etc.i got my gp with 30000 on it and the first thing i did was flush the dex and put in green and i have no sludge or mud looking crap on my radiator cap when i take it off.how many can say that that run dex?just google dexcool problems and have a field day!lol
  12. #12 Re: sludge in coolant
    4-5 years?
    I'd hope you'd change it before then.
    2 years tops for any coolant imo.
    Gotta keep fresh additives for best corrosion protection.
  13. #13 Re: sludge in coolant
    Pennsylvania
    Quote Originally Posted by rampage View Post
    There are radiator shops? Well, regardless, yours are full of worthless idiots and you'd be silly to pay them any money. Read the dang bottles, for crying out loud.
    Flush/Fluid Swap Recommendations:
    "green": 2 years
    long-life "green":3-4 years
    dex-cool: 5 years
  14. #14 Re: sludge in coolant
    Maintenance is maintenance.
    I fear of how your iridium plugs look after 100,000 miles.
  15. #15 Re: sludge in coolant
    Dec 2010
    ky
    heres the point that a few people are missing. most people are not like us and do not change thier coolant every 1 or 2 years.they read thier manuals and it says dexcool is good for 100000 miles wtf gm?like i said this stuff turns to sludge fast.so why are we having all the failed water pumps, radiators,heater cores,leaking intakes and gasgets,because gm says its good for 100000 thats why!when gm was using the green you could get away with that but not anymore.thier is or was at least a class action lawsuite against gm for this because so many people have had the same problems.
  16. #16 Re: sludge in coolant
    Pennsylvania
    Isn't
    Dexcool lasts 5 years OR 150,000 miles (GM recommends 100,000 miles in some of their manuals though (75k in '96, I think?) - still 5 years). Most people only drive 50,000 - 75,000 miles in 5 years. 5 years is therefore your limitation.
    This means that if you drive a 1997 GP and you take perfect care of it, you're on at least your third radiator-full of Dex-Cool by now - the number might be higher than that, since you might have replaced LIM gaskets a couple of times before the aluminum ones came out in 2005.
    Some pressure caps are faulty and do not seal out air, allowing dex-cool to evaporate, allowing iron to rust (producing iron oxide, which is what makes it chunky) since it does not coat the metal the way "green" does. This is not dex-cool's fault. It is your responsibility to constantly check your fluids to ensure that it does not get low.
  17. #17 Re: sludge in coolant
    There is a class action lawsuit because people aren't the brightest and can't follow the two things i mentioned above.
  18. #18 Re: sludge in coolant
    Dec 2010
    ky
    u have to feel sorry for people who are not mecanically inclined.
  19. #19 Re: sludge in coolant
    Or those who can't read where it says "dex-cool only".
    If you're getting a regular oil change they check your coolant...
    At least any good shop would.
  20. #20 Re: sludge in coolant
    **** I change my plugs 2 times a year....
    I've done a coolant flush 2 times this past year as well.
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. Brown Sludge under radiator cap
    By streetsmart in forum General Tech Discussion
    Last Post: 03-22-2009, 01:16 PM
  3. Which coolant to use...
    By Rickochet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 08:34 PM
  4. coolant ?
    By 04GTP in forum Off Topic Discussion
    Last Post: 06-24-2008, 09:42 AM
  5. dex-coolant BAD !!
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2008, 08:13 PM
