Thread: Another blower motor?
Results 1 to 14 of 14
  1. #1 Another blower motor?
    SE Level Member rocketron's Avatar
    Dec 2010
    B.C. Canada
    New here and sorry if this has been asked before, I searched and couldn't find an answer. A '98 Grand Prix. No speeds 1-4, 5 ok. Replaced resistor pack, same thing. I have 12-14 volts at fan on 5, 1-4 nothing. There is power going into resistor but none out on 1-4, but all wires for speeds 1-4 from switch have power in speeds 1-4. I am kinda stumped here, fan switch is working (checked with meter). Any ideas before I spend a bunch more $'s would be awesome. Thanks.
    BTW nice looking site.
  2. #2 Re: Another blower motor?
    GT Level Member GrandPrixSE's Avatar
    Jun 2010
    Indy
    Quote Originally Posted by rocketron View Post
    Well I'm having the same problem also. 1-4 gets nothing, while 5 works. I'm thinking of replacing the controls.
    2000 Buick LeSabre Custom - 3800 Series II V6
    1998 Buick LeSabre Custom - 3800 Series II V6 ​SOLD!
  3. #3 Re: Another blower motor?
    Charles City, IA
    You could have gotten a bad resistor pack.
    SMGPFC Two Nipple General
  4. #4 Re: Another blower motor?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    replace your ignition switches already, you two.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  5. #5 Re: Another blower motor?
    Jun 2010
    Indy
    Quote Originally Posted by noreasonwhyy View Post
    and how much would this cost to fix and how hard is it. LOL
  6. #6 Re: Another blower motor?
    Dec 2010
    B.C. Canada
    Haven't replaced ignition yet. Wanted to see if I was missing something before I went down that road (they are about $300 here). Is there a procedure to test the resistor pack?
  7. #7 Re: Another blower motor?
    Akron Ohio
    ITS THIS DOOOOOETTTTT
  8. #8 Re: Another blower motor?
    Dec 2010
    B.C. Canada
    Ok gonna try the ignition switch. Let ya know if it works. Is it worth trying to do the "fix" on it or just replace it and do it once instead of twice?
  9. #9 Re: Another blower motor?
    Donating Users busmech's Avatar
    Apr 2009
    Minneapolis MN
    You can test the resistor pack with a multimeter ($8.00 @ Harbor Freight tools) you should see different ohm readings across the terminals of the pack...if youve never used a multimeter, ohms are the scale with the kinda upside down U...good luck...
    "Turbocharging is nice...but I'd rather be BLOWN!!!
  10. #10 Re: Another blower motor?
    Dec 2010
    B.C. Canada
    Quote Originally Posted by busmech View Post
    Was looking for some numbers to look for.
  11. #11 Re: Another blower motor?
    Charles City, IA
    So you have power at the harness going to the resistor for 1-4 and nothing out of the resistor going to the motor, that is a bad resistor.
  12. #12 Re: Another blower motor?
    Dec 2010
    B.C. Canada
    I have 12 volts at all 4 wires at the same time. Replaced ignition that didnt work. New resistor pack installed. Getting resistance through pack in all 4 speeds with ohm meter. Gonna try a fan switch next, had to order one, this thing is kickin my butt.
  13. #13 Re: Another blower motor?
    GT Level Member sic6's Avatar
    san marcos, tx
    If your getting power at all speed at the same time then you might have a melted wiring harness creating a short to power. I would trace the harness from the climate controls to the blower motor just to make sure its not shorting out. If all is good then its probably the blower swicth in the climate controls.
  14. #14 Re: Another blower motor?
    Dec 2010
    B.C. Canada
    I got another new resistor and it fixed the problem. Thanks for the help.
  1. Blower Motor in 97 SE 3.8
    By jfmurph in forum Introductions/Noob Questions
    Last Post: 07-20-2010, 06:51 PM
  2. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  3. blower motor
    By littlenoz in forum General Tech Discussion
    Last Post: 12-30-2009, 07:10 PM
