Thread: THrottle position sensor
Results 1 to 8 of 8
xsvtank THrottle position sensor 11-19-2010, 04:20 PM
Pepino Re: THrottle position sensor 11-19-2010, 04:55 PM
TheOtherNick Re: THrottle position sensor 11-19-2010, 08:06 PM
xsvtank Re: THrottle position sensor 11-21-2010, 01:28 AM
Kejross Re: THrottle position sensor 11-21-2010, 02:21 AM
gtpinsc Re: THrottle position sensor 11-21-2010, 08:58 AM
Slumhustler Re: THrottle position sensor 11-27-2010, 05:03 PM
gtpinsc Re: THrottle position sensor 11-27-2010, 07:17 PM
  1. #1 THrottle position sensor
    SE Level Member xsvtank's Avatar
    NJ
    Hey guys I had just replaced my tps/ pedal position sensor and I keep getting the ses code for the sensor what can it be ?
  2. #2 Re: THrottle position sensor
    Brewcity, WI
    are you saying the code went away after you replaced it, and now its back on?
    or it has been on the whole time?... how long has it been on?
    maybe unplug your battery for 1/2 hour.... kinda resets the PCM. Just don't beat on your car while driving after "reboot"..... the PCM has to re-learn a bunch of parameters.
    not sure if that would help...?
    Self-denied SMGPFC member #1
    SEARCH works!
  3. #3 Re: THrottle position sensor
    Charles City, IA
    Could be a bad ground, bad 5Vref, bad pcm, bad wire.
    SMGPFC Two Nipple General
  4. #4 Re: THrottle position sensor
    NJ
    i replaced it and it just came back on and ill check the wires and i tried unpluging the battery for about an hour to let it "reset"
  5. #5 Re: THrottle position sensor
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Use a scanner to see if its sending out a signal... Then with the car off make sure it reads all the way up to 100 and comes back to rest at 0%
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  6. #6 Re: THrottle position sensor
    Jul 2008
    sumter,south carolina
    i had a vac leak cause a TPS code.. my rubber t under the snout of S/C came completely off. i replaced TPS 3 times before i figured it out it was a vac leak.
    02 GTP with mods 05 GP for DD
  7. #7 Re: THrottle position sensor
    Feb 2010
    Maine
    I'm kicking myself should have come here first....my car was running like garbage scanned it and got a few codes and I figured that it was the MAF sensor...had a TPS code too.....so of course I figured it was the maf...so got a new one of those...seemed to be running better but would still die after idling for a few seconds....checked on here saw that post....so figured before I buy more stuff I should check the stupid stuff first....and sure enough the T had a split in it that had caused it to fall off from the intake manifold.....so yea lesson learned check the dumb stuff first....
    Good looking out I was about to set my car on fire.
  8. #8 Re: THrottle position sensor
    Jul 2008
    Quote Originally Posted by Slumhustler View Post
    trust me i kno that feeling... glad i could help.
  1. Throttle Position Sensor Optimization
    By silverstreak in forum How To Write-Ups/Tech Tips
    Last Post: 12-25-2010, 03:06 PM
  2. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
  3. cam position sensor
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-18-2009, 02:16 PM
  4. HELP Crank Position Sensor
    By catcamvegas in forum General Tech Discussion
    Last Post: 08-02-2008, 10:30 AM
