Thread: how bad is this with a 2.5
Results 1 to 11 of 11
  1. #1 how bad is this with a 2.5
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    running a 2.5 pulley with perfectly clean rotors....is this bad and how much loss will is see?
  2. #2 Re: how bad is this with a 2.5
    Delaware, OH
    I wouldn't even try it. Your risking alot. Way more heat from the additional friction of metal to metal, and you'll wear them out pretty quick since metal doesn't slide over metal very easily without any coating on it.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  3. #3 Re: how bad is this with a 2.5
  4. #4 Re: how bad is this with a 2.5
    Charles City, IA
    You will make like 5lbs of boost and a **** ton of heat.
    SMGPFC Two Nipple General
  5. #5 Re: how bad is this with a 2.5
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    you might loose a psi or two. 2.5 pulleys pretty pointless aswell. Run more timing on the 2.6 or 2.7. The 2.5 is past the threshold of diminishing returns
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: how bad is this with a 2.5
    Charles City, IA
    Quote Originally Posted by 01gpgt01 View Post
    I made like 8psi on a 3.2 with half coating.
  7. #7 Re: how bad is this with a 2.5
    Feb 2010
    somewhere cold
    well new coating and no meth it is then...anyone wanna buy a devils own meth injection kit?
  8. #8 Re: how bad is this with a 2.5
    GT Level Member Joe m's Avatar
    mesa,az
    the meth kit is not what caused the coating to come off. aslong as your not running the detergent windshield fluid ur fine. its a coating flaw from factory, keep the meth get new rotors.
    mods - ssac headers,custom intake,ported blower, cut lim for i/c, al104's,180*t-stat,3.4.
  9. #9 Re: how bad is this with a 2.5
    Jersey
    there was a write-up by a Holden commodore guy on here. He re-coated his own rotors
    16' wrx sti- stock
  10. #10 Re: how bad is this with a 2.5
    key is retiming the rotors and not damaging the seals. difficult to source.
  11. #11 Re: how bad is this with a 2.5
    Meth doesn't harm rotor coating...I don't know why you keep saying it does...WATER will damage and peel the coating off of GenIII rotors because GM didn't use decent coating from the factory. They fixed that on the GenV which is why you never see any set of GenV rotors peeling/flaking/polished. I bet if you threw a good set of rotors in your car would knock from the 2+ psi of boost you'd be getting.
bad
