Thread: transmission drain
Results 1 to 3 of 3
  1. #1 transmission drain
    Las Vegas
    If I cut my transmission oil lines to install my trans cooler will that drain the fluid, or do I still need to drain it at the pan?
  2. #2 Re: transmission drain
    GTX Level Member colindunn's Avatar
    Aurora, IL
    the pan is a low point where the fluid sits. my guess would be to still drain it at the pan to remove most of the fluid.
  3. #3 Re: transmission drain
    Charles City, IA
    You wont loose much out of the lines. Dropping the pan will drain about 8qts.
    SMGPFC Two Nipple General
  1. Drain Plug in Trans pan
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 11:32 AM
  2. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  3. drain plug oil leak
    By 05grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2010, 02:34 PM
  4. help! - oil drain plug
    By mpiacent in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-14-2010, 05:27 PM
  5. Oil drain plug
    By SlowM90 in forum General Tech Discussion
    Last Post: 12-22-2009, 12:05 PM
