Thread: 96 gt engine wont turn over
Results 1 to 10 of 10
  1. #1 Re: 96 gt engine wont turn over
    SE Level Member JHGTP's Avatar
    Nov 2010
    Sacramento
    Ok, i have the same problem here with my 2004 GTP. I checked all the electrical circuits with my DMM, the voltage and resistance is within spec on the starter circuit and battery. I've replaced the starter itself, tested the P/N safety switch, and tested the Ignition switch and all are working fine. I've even pulled the spark plugs one by one to see if maybe my luck was bad enough I had a Hydrolock in a cylinder but that wasn't the case. Everything acts normal but the engine will not rotate at all. I'm going to buy a breaker bar and socket today to try and rotate the motor by hand but aside from that does anyone have any more ideas? I really don't want to call an expensive tow-truck...
  2. #2 Re: 96 gt engine wont turn over
    Nov 2010
    Sacramento
    LOL, so yeah the whole no start condition was such a dumb easy fix. After I ran all the tests I could think of my GF said maybe I should check the battery. So I used my DMM to check for battery voltage and got 11.4v. After humbly thanking her I charged the battery and the car ran fine. I did have the starter tested at the shop and they said it was dead so it's a good thing I installed a new one. My alternator was also out so I had to replace that one as well. For future reference to anyone who wants to install a nice sub system in their car...invest in a Capacitor and make sure your alternator can handle the amp draw. It'll save your alternator and you a lot of hassle, lol.
  1. TCS wont turn on
    By jmalin72207 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 01:19 AM
  2. car wont let me turn it off??
    By 02blackgpgt in forum General Tech Discussion
    Last Post: 04-25-2009, 08:14 AM
  3. please help, air wont turn off
    By red60degreeGP in forum General Tech Discussion
    Last Post: 04-23-2009, 06:26 PM
  4. My Car wont Turn off !!!
    By Billyboi6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-15-2008, 01:02 AM
  5. Car wont turn off !?!
    By Billyboi6 in forum Northeast
    Last Post: 11-11-2008, 12:54 PM
