Thread: Ongoing Problems...
Results 1 to 10 of 10
  1. #1 Ongoing Problems...
    SE Level Member WolfLord's Avatar
    Feb 2010
    missoula, montana
    Soo... the wife wants me to figure out what's wrong with "our" (her) car. The car has had 3 major problems in the past 6 months and we fixed one of the three. The first was the common key getting stuck in the ignition problem. We removed the solenoid from within the column and now there's no problem. About a month after doing that the car started having intermittent starting problems. Randomly when going to start the car it will "click" (as it tries to start) but will not try to fire the engine or anything. If you release and go back to off and then start it again sometimes it will start fine. Other times might take 2 or 3 tries. Randomly when going to start it will hesitate then turn over (like, turning the key to start then waiting half a second before starter turns over the engine). This is an ongoing, annoying, problem. I've been told it may be the starter going out, anybody else had this problem?
    Now problem 2- and this has been going on for awhile, and only happens in fall/winter/spring (it's Montana ya know...) when under about 45. When we get in the car and press down on the brake the shifter button won't allow itself to be pressed in all the way to shift out of park. I've found that if I practically stand on the brake to depress it I can get it to shift (i.e. both feet on the brake) but my wife is no where near strong enough to do that. Is there a way to disengage whatever "safety" part is put in place to not allow the car to shift out of park unless the brake is fully depressed? It's getting really annoying >.<
    Any help would be appreciated, thanks, you guys are the best!!
    Edit: Car is a 1999 GP GT Coupe (as if the coupe matters =P)
  2. #2 Re: Ongoing Problems...
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    there is a tab next to the shifter that says shift lock.. you have to pop the cover off and turn it i think? its in the manual
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  3. #3 Re: Ongoing Problems...
    Feb 2010
    missoula, montana
    yeah, ive been thinkin about doing that and just leaving a screwdriver in the car, haha
  4. #4 Re: Ongoing Problems...
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    easiest fix is to replace the ignition switch. it will correct the shift out of park problem as well as the key not coming out. i can't assure you the starting clicking will go away, but i wouldn't be surprised.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  5. #5 Re: Ongoing Problems...
    Feb 2010
    missoula, montana
    I'll look into it. My brother and I may be putting a remote start in anyways, so since we'll have it all tore apart we might as well put a new ignition switch in.
  6. #6 Re: Ongoing Problems...
    i've heard those can easily complicate things and cause unforeseen issues.
  7. #7 Re: Ongoing Problems...
    MO
    honestly i'd stay away from a remote start, especially a DIY one. We bought a $100 one that I installed myself, before long it blew my BCM which cost us over 600 dollars to get fixed. Those things just get wacky and unpredictable
    <brandonl2000> LMAO D!!
  8. #8 Re: Ongoing Problems...
    Feb 2010
    missoula, montana
    hhmm might look into getting one professionally done??
  9. #9 Re: Ongoing Problems...
    GTP Level Member SuperSport's Avatar
    Michigan
    Or just have yours removed...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  10. #10 Re: Ongoing Problems...
    Feb 2010
    missoula, montana
    I don't have one installed currently...
  1. HID problems AGAIN
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 07-26-2010, 07:12 AM
  2. three problems
    By jmanrta in forum General Tech Discussion
    Last Post: 03-31-2010, 10:40 AM
  3. A few problems with my GTP
    By Girevik in forum General Tech Discussion
    Last Post: 02-10-2010, 02:08 PM
  4. 07 gxp with nav mp3 problems
    By pjs29 in forum General Tech Discussion
    Last Post: 08-22-2009, 01:11 PM
  5. ongoing Issue with Ignition Main 1
    By palmergg in forum General Tech Discussion
    Last Post: 08-12-2009, 12:12 PM
