if i were me, i wouldnt run it again. if i were you, i would debate it.
its hard to dial in and keep it tuned correctly. its best used in small doses to clear up small amounts of knock and thats about it.
you should be running the meth higher up in the boost. i STARTED spraying at 7 psi and put the max at like 12-13 psi. that will be way better for you and easier to tune. right now youre dumping too much in.
