Thread: Aeroforce gauge performance results
Results 1 to 10 of 10
  1. #1 Aeroforce gauge performance results
    Jan 2009
    connecticut
    So I finally used my aeroforce gauge to see what the 1/4 mile and 0-60 mph times are. Did two runs on two different days. Im pretty good at launching with little to no wheel spin. just not sure how accurate the aerofoce is with this feature. Here were my results, mods in signiture. accurate?
    first run
    1/4 mile 13.76 @ 101mph
    1/8 mile 8.96 @ 81mph
    0-60 mph 5.51 seconds
    Second run
    1/4 mile 13.71 @ 102mph
    1/8 mile 8.86 @ 81 mph
    0-60 mph 5.20 seconds
    K & N cai / 3" downpipe / hi-flow cat / u-bend delete / 180 T-stat / ceramic coated plog & crossover / Overkill pcm / 3.5" pulley / zzp stage 1 TB / auto lite 104's / msd wires / poly mounts / slp front and rear sway bars / bmr trailing arms /
  2. #2 Re: Aeroforce gauge performance results
    Kansas
    They are okay for accuracy. But the car can't account for wheel spin. Like if you spin a lot the car thinks your moving farther then you really are. Also got to take in account for hills and what not. But not bad times depending on amount of wheel spin.
    SOLD 1999 GT Silvermist TS
  3. #3 Re: Aeroforce gauge performance results
    Ocala, FL
    Hmm, is this in the regular menu of the aeroforce, mine must be too old to have it if so?
  4. #4 Re: Aeroforce gauge performance results
    Kansas
    Its called performance.
  5. #5 Re: Aeroforce gauge performance results
    My car makes 500 HP and 550 ft lbs of torque according to my aeroforce.
    What does this tell you?
  6. #6 Re: Aeroforce gauge performance results
    Donating Users chrisb's Avatar
    Bucyrus, OH
    sounds like its spot on!
    Mine was really off also said i ran like 12.7 or somthing, idk
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  7. #7 Re: Aeroforce gauge performance results
    utah
    you need to adjust a few things to get the hp and tq semi accurate...alltitude and such
  8. #8 Re: Aeroforce gauge performance results
    alt is adjusted
  9. #9 Re: Aeroforce gauge performance results
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    Mine was pretty accurate on the performance other than the wheel spin. ET was messed up, but trap was dead on.
    Aeroforce
    12.6 @ 115
    Track
    13.0 @ 115
    Retired
    Turbo'd
  10. #10 Re: Aeroforce gauge performance results
    Jan 2009
    connecticut
    Well i figured the 1/4 seems close what the car ideally should be running. wheel spin was minimal. both times were pretty close and were done on two totally different flat roads. The 0-60 time seems a little fast to me. but could be close i guess.
  1. Aeroforce gauge ?
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 04-16-2010, 06:04 PM
  2. aeroforce gauge
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2009, 12:01 PM
  3. Aeroforce scan gauge performance mode
    By spidamanSS in forum General Tech Discussion
    Last Post: 07-02-2008, 02:25 PM
  4. Aeroforce gauge...
    By duane9586 in forum General Tech Discussion
    Last Post: 07-01-2008, 01:32 PM
