Thread: Small battery
Results 1 to 8 of 8
Arkanzan Wheeler Small battery 05-22-2008, 04:56 PM
Sabrewings Re: Small battery 05-22-2008, 06:10 PM
archemedes Re: Small battery 05-22-2008, 06:57 PM
Arkanzan Wheeler Re: Small battery 05-22-2008, 08:00 PM
s1795so2 Re: Small battery 05-23-2008, 12:52 AM
BADAZGTP Re: Small battery 05-24-2008, 07:20 PM
02BlueGT Re: Small battery 05-24-2008, 08:51 PM
BADAZGTP Re: Small battery 05-24-2008, 10:33 PM
  1. #1 Small battery
    SE Level Member Arkanzan Wheeler's Avatar
    Apr 2008
    I was thinking about saving some weight to my car by getting one of those small batteries like the Odyssey or Genesis when I came across this nice write up so I figured I would share it.
    Stealth 316 - Dyna-Batt Battery
    2000 Daytona 500 Edition
  2. #2 Re: Small battery
    Barksdale AFB, LA
    Not many CCA. They'd go dead quick in winter if your car is having trouble starting.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Small battery
    Saraland Alabama
    they are not designed as a main starter battery for everyday use, and will not last long if used that way (the odyssey was being heavily marketed to car audio shops not too long ago)
  4. #4 Re: Small battery
    Apr 2008
    Yeah, that is basically what that write up found. I am still going to look around and see what is the smallest 800 CCA battery I can find. My battery is still good now so I am looking before I am pressed for time.
  5. #5 Re: Small battery
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Look into carbon fiber batteries, search google, and it should come up with a few options that will fit the light weight and cca requirements you want. There are at least 2 companies that I know make them and are reasonably priced.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  6. #6 Re: Small battery
    Apr 2008
    Chillin at the Beach , VA
    Even though our batteries do have some weight to them, being in a FWD car, it would help a little on the traction side. Not much difference, but every little bit helps. Just my couple pennies worth. Just thought it would be something to think about.
  7. #7 Re: Small battery
    Hoffman/Schaumburg, IL
    ^^ That makes sense, but most of the weight shifts rearward during acceleration, so any weight you can cut is good weight
  8. #8 Re: Small battery
    Apr 2008
    Quote Originally Posted by 02BlueGT View Post
    True, I didn't think of it like that, I was thinking more on the height holding the front down more so when it does shift the weight it wouldn't pull the front up as much.
  1. Total new system,, small space 2005 supercharged
    By scoobyydooooooo in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 10:27 PM
  2. Small SPL contest in Houghton Lake
    By GOINDEF in forum Shows and Events
    Last Post: 04-08-2008, 11:46 AM
  3. too small of a s/c belt???
    By IndeedSS in forum General Tech Discussion
    Last Post: 03-31-2008, 03:06 PM
  4. Battery post connectors
    By IndeedSS in forum Audio, Security & Visual Electronics
    Last Post: 03-24-2008, 10:56 AM
  5. Turbo Civic Vs. Small block Bronco !
    By Meemperor in forum Track Sessions and Kills
    Last Post: 02-02-2008, 05:40 AM
