Well,on the weekend I completely removed my remote starter from my car and it fixed nothing.So I decided to check each and every fuse in both fuse boxes...nothing.I checked for voltage at the headlamp breaker in the glovebox and found that I was only getting 9V,so I took a wire from the battery and tried it on the load side of the headlamp breaker spot in the glovebox and my lights came on.I thought this was my problem but it turned out not to be.For the time being I left that wire in the fusebox so that I can have lights,not sure if I have hi or low beams,but for the time being I have some sort of lighting.I'm gonna change the ignition switch on the weeked and get rid of that wire in my fusebox before my car burns.From doing some searching on clubgp and here,I've noticed that I have a few of the symptoms of a bad ignition switch...just weird electrical problems....hi beam indicator in on all the time,all the dash lights go on and off randomly,the fast chime that dings when you leave your lights on is constantly chiming without the key or lights being on.I have an ignition switch that I bought from Ed a while back,so I might as well try it.Thanks for the help so far.
Blair
