Thread: Idle is going up & down... sometimes !
Results 1 to 4 of 4
  1. #1 Idle is going up & down... sometimes !
    SE Level Member 9ordohz's Avatar
    CA
    well since i installed my headers.. other than some lil probs that came up.. the one that i dont know what it might be is when my idles goes up & down.. ill be driving & let go of the gas i my revs go from... 500 to 1.1k :/ i already found the culprits for the other probs (Misfires & crappy mpg) but this one is still in the air (maybe even literally, sensor wise haha) since i cant find the cause..
    what can i do to fix this :/
    thanks
    99Gtp*5% tint all around *Hids: 1ok headLights, 1ok Foggs *CUSTOM CAI *3"CATBACK *SLP HEADERS *Satin Blk torQue starz *7" Flip Screen *15" Sub *1800w kw amp *1200w 4ch. *SS Epicenter (: *&MORE TO COME ! *JUST STARTING OUT .....
  2. #2 Re: Idle is going up & down... sometimes !
    Donating Users Ibwrong's Avatar
    Oklahoma City
    I would guess Vac leak of some sort, probably not a big one bug any vac leak is bad. Gets some carb cleaner and start spraying all the vac lines while the car is running, when your RPMS drop you also find your vac leak.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: Idle is going up & down... sometimes !
    CA
    theres a lil line..short one, cant be really specific since i cant really remember whats around it..it looks dried up.. but i never actually took it into consideration :O its located right on top of the S/C i think it goes into a T or something like that..ill take a look today & post it up with details..if its just that (hopefully).. where can i get it? thanks..
  4. #4 Re: Idle is going up & down... sometimes !
    CA
    replaced vac line, it was totally dried up. replaced it & it still goes down but way way way less than before. before it was like 1k rpms now its just 100 - 200 rpms at the most. you can barely notice it but its still there, way better than before
  1. Won't idle; missing above idle if you can get it started
    By jrece in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 11:24 PM
  2. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  3. idle
    By kylehendy79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2010, 06:21 PM
  4. Ruff Idle
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 12:10 AM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
