Thread: how can i repair this
Results 1 to 6 of 6
  1. #1 how can i repair this
    Apr 2009
    freehold,ny
    my lights in my gear inducator consule ( or whatever you would call it) stopped working how can i fix this its a 07 na
  2. #2 Re: how can i repair this
    Wichita
    You may just have a burnt out bulb. Check the fuses in you fuse box first. Then if it isn't a blown fuse & you think you can do it; dismantle your center console and replace the bulb.
  3. #3 Re: how can i repair this
    Apr 2009
    freehold,ny
    i've checked all the fuses so yeah im gonna have to replace the lights, is this tricky or any tips
  4. #4 Re: how can i repair this
    Jul 2010
    Outside ATL
    just be gentle on all the plastic bits when you pop the console out. Make sure you drink holder is out and put your gear shift in 1.
  5. #5 Re: how can i repair this
    Banned
    Sioux Falls, SD
    In order to change this bulb u need to take the two bolts out of the rear of the counsle one on each side then one on each side towards the front. You will also need to take the shift knob off, it is a small phillps on the front of the knob. When u go to pull it off it is hard because they used a clip towards the back. aslo wires to watch out for. The bulb is a 194 located under the shift selector. any questions feel free to ask
  6. #6 Re: how can i repair this
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    i believe you put it in second gear not first gear
  1. Windshield Repair
    By cmw1876 in forum General Tech Discussion
    Last Post: 09-26-2009, 12:12 PM
  2. windsheild repair
    By Ironwarrior in forum Visual/Body Modifications
    Last Post: 07-09-2009, 04:09 AM
  3. windsheild repair
    Last Post: 07-08-2009, 05:14 AM
  4. Intercooler repair???
    By Smokin2000gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 03:20 PM
  5. Wheel repair?
    By TDCRacing in forum Tires & Wheels
    Last Post: 07-02-2008, 11:28 AM
