Thread: 2007 GXP Door Skins
Results 1 to 4 of 4
  1. #1 2007 GXP Door Skins
    SE Level Member yukontornado's Avatar
    May 2008
    Eaton Rapids, Michigan
    How do you remove the interior door skins to get to my monsoon door speakers without busting the clips. What is the secret on these doors???? HELP.
    Yukontornado
  2. #2 Re: 2007 GXP Door Skins
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    did you remove the two screws behind the door grab handle? If so it should be just a matter of using a small screw driver, or panel poppers and starting on the (this is the drivers side door panel, reverse left and right directions for passenger) bottom left and working to the right along the bottom; then moving to the left side going upward. Once all the clips are out, also make sure that tringle pice at the top right corners clip is also out, just lift and tada you have the door panel off.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  3. #3 Re: 2007 GXP Door Skins
    May 2008
    Thanks for the info. Yeah, I pulled the two screws and the triangle piece off, but by the speakers the panel seems to be stuck and I didn't want to pull too hard.....I guess I will try a little more MUSCLE
  4. #4 Re: 2007 GXP Door Skins
    alhambra, Il
    yeah they aren't as fragile as some of the older style clips where they brake at the slightest bit of pressure.
    I was hoping the instructions didn't confuse, as it was kind of long winded. haha.
    -steven-
    Steven Oliver
  1. Removing the door panels
    By TNTSS in forum General Tech Discussion
    Last Post: 05-20-2008, 02:57 PM
  2. Mods for 2007 3.8
    By BrianHoward in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-27-2008, 07:08 PM
  3. Favorite Type/Suggestion of Tires for a 2007 Base Grand Prix
    By POLECAT2007 in forum Tires & Wheels
    Last Post: 03-18-2008, 06:18 PM
  4. GM sold more in 2007 than Toyota
    By Rocket468 in forum Off Topic Discussion
    Last Post: 01-24-2008, 10:19 AM
