Thread: tightening serpentine belt
Results 1 to 3 of 3
  1. #1 tightening serpentine belt
    GT Level Member tmackster's Avatar
    San Antonio, TX
    ok..i just replaced the heater hoses on my car b/c one of them cracked and was causing my car to overheat...went to put everything back together and now my serpentine belt has about an inch of slack...HOW DO I MAKE THE BELT TIGHT!?! i have checked and the belt is on right..it just has some slack now!
    '06 GP GT // Debadged // 20" Niche Venice rims w/toyo proxes4 tires, ram air inferno hood, front air dam, SE rear valance, black l.e.d. tail lights, CAI, MSD Ignition wires, Pioneer 6x9, & 10,000K HID headlights!!!
  2. #2 Re: tightening serpentine belt
    Charles City, IA
    Then tensioner should spring back and put tension on the belt. How did you get the belt off if you dont know how the tensioner works?
    SMGPFC Two Nipple General
  3. #3 Re: tightening serpentine belt
    San Antonio, TX
    thnks for the post. but i actually had the belt on wrong..i found the layout of the belt online and fixed the belt right after my post! but...my car is still leaking coolant. and its getting on my belt and throwing the coolant under my hood...looks ugly but as long as i keep the radiator filled it doesnt overheat...i think its time to change the water pump!?!
  1. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  2. serpentine belt
    By rmil03 in forum General Tech Discussion
    Last Post: 09-01-2010, 05:44 PM
  3. serpentine belt
    By Getagrip in forum General Tech Discussion
    Last Post: 04-21-2010, 05:26 PM
  4. Serpentine Belt Trouble
    By butch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2009, 03:09 PM
  5. serpentine belt
    By keenan00gtp in forum General Tech Discussion
    Last Post: 01-25-2009, 11:43 AM
