Thread: Left rear speed sensor replacement
Results 1 to 2 of 2
  1. #1 Left rear speed sensor replacement
    Morehead, Ky
    I'm new to the forum and just picked up a sweet 99 gt. The ABS light and trac light are constantly on. I had a shop run the codes and they said the problem is left rear speed sensor. I've picked up a new one but am unsure of how to get the old one out. Do you have to remove the emergency break assembly? I've done some searching for a writeup but have not been successful so far. Any write ups? Any suggestions?
    Thanks,
    Steve
  2. #2 Re: Left rear speed sensor replacement
    Donating Users
    South Deerfield, MA
    IIRC, you have to disconnect the e-brake cable from the back and unplug the speed sensor connector. Remove the caliper and rotor. Use the hole in the front of the hub to remove the 4 bolts holding the hub to the knuckle. Reinstall the same way.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. Vehicle Speed Sensor
    By bct717 in forum Chevrolet Monte Carlo
    Last Post: 12-08-2010, 08:39 PM
  2. ABS speed sensor
    By m1sterb0b in forum Tires & Wheels
    Last Post: 12-21-2009, 10:14 PM
  3. Where is the Speed Sensor on a 99 Gtp
    By millertyme771 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2009, 02:46 PM
  4. ABS Speed Sensor Issues
    By foghelmut in forum General Tech Discussion
    Last Post: 10-05-2009, 09:08 AM
