Thread: serpentine belt
Results 1 to 9 of 9
  1. #1 serpentine belt
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    okay so on my 2000 pontiac grand prix the supercharger belt broke and destroyed my serpentine belt. I feel like its going to be a very big process on doing this, so i was wondering if anyone knew the easiest way to do it. thanks
  2. #2 Re: serpentine belt
    GTX Level Member cerick08GP's Avatar
    Well, assuming the belt broke from normal wear, it is a very easy task replacing the belts. You just need to route the belts and use a wrench to compress the tensioners when you slip the last part of the belts over. The belt routing diagram should still be under the hood and this is all wrench turning 101 stuff so no worries. But just to throw you off now is the perfect time to inspect your idler/tensioner pulleys, it wouldn’t surprise me a bit if one was bad.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: serpentine belt
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    ^^^^ x2 on the pulleys and they are fairly cheap and easy to change
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  4. #4 Re: serpentine belt
    how do i know if there bad, just spin them and they should spin nice and smoothly?
  5. #5 Re: serpentine belt
    Nov 2009
    A little late
    A bad pulley has a "whinning" sound to it when spun by hand. Any others have a way to describe how the bad pulley will sound. Mine had the whinning sound so bad that you could hear it increase and decrease with RPM's while sitting in the car.
  6. #6 Re: serpentine belt
    how do i get off the tensioner pulley mine whines and it wont come off
  7. #7 Re: serpentine belt
    turn the bolt the opposite direction of the one that lets you take the belt off.
    It helps if you take the coolant bottle out first. two 10 MM nuts hold on the bottle and then the clip on the fuse box and you can lay it between the oil filler cap and rad.
    Then a 15 MM socket and ratchet and you should be set.
  8. #8 Re: serpentine belt
    thats the for the tensioner assy.
    and i believe they're 15 MM on his year. Three 15 MM bolts.
    Its one 15 MM to take the pulley off.
  1. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  2. tightening serpentine belt
    By tmackster in forum General Tech Discussion
    Last Post: 10-22-2010, 11:03 PM
  3. serpentine belt
    By rmil03 in forum General Tech Discussion
    Last Post: 09-01-2010, 05:44 PM
  4. serpentine belt
    By Getagrip in forum General Tech Discussion
    Last Post: 04-21-2010, 05:26 PM
  5. serpentine belt
    By keenan00gtp in forum General Tech Discussion
    Last Post: 01-25-2009, 11:43 AM
