Thread: Engine bogging down
Results 1 to 9 of 9
  1. #1 Engine bogging down
    dekalb, il
    I have a 2002 grand prix gtp. 3.8L SC. The engine is bogging down shortly after i start the car. I was told it was a air to fuel ratio so i bought a reprogrammed PCM with the correct ratio input. That PCM didnt help anything and the car keeps dying on me. Any suggestions on how to correct this and get it fixed so i can drive my car.
    Mods-
    3.25" SC Pulley
    SLP headers/downpie/cat
    Borla Cat-back
    MSD wires and coils
    NGK Iridium plugs
    K&N Intake.
  2. #2 Re: Engine bogging down
    Jul 2008
    sumter,south carolina
    thats not enuff mods for a 3.25 just sayin.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Engine bogging down
    first off you need to be running a 3.4" pulley more likely than not...
    Buying a PCM thats corrected for the AFR is impossible. (unless people did e-tuning, but thats cost prohibitive)
    Buy a 3800performance.com PCM for a 3.4 pulley setup and put a 3.4 on it.
    your car will run better and be much safer.
  4. #4 Re: Engine bogging down
    dekalb, il
    I order all my parts from 3800performance.com. I just put the reprogrammed PCM on this past Friday. The guys their said the pulley shouldnt have anything to do with it and the new PCM should have fixed it.
  5. #5 Re: Engine bogging down
    Their PCM's are setup for a 3.4 pulley.
    If you put on a 3.25 you'll run lean if you're tuned for a 3.4.
    Without knowing anything more than "it bogs" I can't really suggest anything.
  6. #6 Re: Engine bogging down
    dekalb, il
    It idles for about 30 seconds then will knock 3 or 4 times until the engine dies completely.
  7. #7 Re: Engine bogging down
    knocking is always bad.
    Whats the engine speed when this happens?
  8. #8 Re: Engine bogging down
    dekalb, il
    Idles high at about 1800 as soon as i start then the first knock takes it down to 1000 RPM then down to about 500 RPM for 3 or 4 engine knocks then just dies.
  9. #9 Re: Engine bogging down
    Charles City, IA
    Pull your plugs I bet they are smash. Time for a new engine, try reading next time.
    SMGPFC Two Nipple General
  1. car bogging down :(
    By Ricky21 in forum General Tech Discussion
    Last Post: 08-19-2010, 12:55 AM
  2. bogging?
    By backinblackgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2010, 05:03 PM
  3. '02 GT bogging down-?
    By Wolf02GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-01-2009, 02:53 PM
  4. Problems with my car bogging down?
    By thenervemann in forum General Tech Discussion
    Last Post: 04-21-2009, 09:05 PM
