Maybe try uploading to a google doc or something? flickr?
this is from photobucket, any better?
Is that the boost solenoid in the picture? It's kinda hard to tell since so up close...
ya your looking from the left side of the car (if your facing the motor) past the boost solenoid towards the TB and its the little hole at the bottom its CONSTANTLY sucking air
hmm..
That's probably the issue then. I think my supercharger may not have that hole (gen V) I'll look at mine when I get home tonight (not my DD), but hopefully someone else can chime in before I do next.
that would be awesome! thank you so much for all your help!
As I feared, my gen V doesn't have anything there![]()
Problem Solved! well Mostly...
so after replacing my MAF and IAC and a new plug wire things were better but not good yet. so i go back in and spray that hole again and sure enough my idle goes right back up i got frustrated and plugged the hole with a piece of paper and i heard a slight hiss... LOL i hunted around for a min and found a SECOND vacuum leak! so i replaced some hose and all is well!
that little hole still sucks air though?im not so sure what that is all about but my car runs great aside from that! thanks everyone for all your help!
As a temporary fix I'd rtv that hole up until you can find out what it is used for...
do i dare do that? i dont want to hurt anything? if its there its there for a reason right? i have been looking but it doesnt seem that anyone else is having the same problem
Is there a stud in the hole for the TB?
im not sure i know what you mean? the TB has one bolt on top and two on bottom all in different locations from the hole. when i took the TB off i noticed that there is a dipped in section in the TB that looks like it leads up insie the TB. im assuming that it suppose to adjust air intake but it wouldnt be filered air? im so lost. i just want to know what this stupid thing is so i can fix it haha
Thanks for the advise i think this is what im going to do but i just dont know enough yet. there has got to be some purpose or it wouldnt be there? im the third owner of this car so i guess it could have been drilled by someone after market but its so perfectly done it looks like it was done in the factory?
I can't see any of the pics since I'm at work but I did return your PM Damon.
