Thread: 2001 GTP w/ 213,000 miles and counting
Results 1 to 8 of 8
  1. #1 2001 GTP w/ 213,000 miles and counting
    Lawrenceville, GA
    Just wanted to share an experience I had today. My '01 GTP has 213,000 miles on her and is doing great. I just changed the plugs and have to admit I was hesitant to roll the engine forward to get access to the back plugs but after I got into doing it I was OK.
    I bought a Haynes manual for her and it has been a life saver along with the tips and encouragement from the forum.
    I have had a couple of MAF sensors go bad and that caused some weird problems and I thought I had one yesterday when the idle speed of the engine just jumped to over 2000 rpm for no good reason. I was just driving along at a low speed and all of a sudden the rpm jumped up and would not come down. Since I needed to replace the plugs and wires anyway I started there but I knew that was not the problem.
    A while back I had changed the IAC valve and decided to check it out just to be sure it was working OK. When I pulled it out I got the valve, the spring and the shaft but the needle was still in the throttle body.
    Looking closer I found the needle was just sitting in the seat and I was afraid it would fall out and land inside the throttle body. I took the shaft out of the valve (it just unscrewed) and threaded it into the needle and was able to extract the needle from the housing and reassemble the valve. I set it to the recommended 1.125 inches in the manual and reassembled it and it worked great.
    The car is running great again and has that old power back that I love so much. I was cruising at 80mph on the on ramp of the freeway and had to slow down to merge
    I do notice it is running a little rough at idle but I just added a can of seafoam to the gas and am running it out to see if that will settle things down. It's OK but I think it can be a little smoother sitting at a light. We'll see.
    Thanks to everyone that contributes on the forum. It is a big help for a mech-tard like me when it comes to working on these beasts but there is a certain amount of satisfaction to working on the car and then doing a successful test drive. It's been a good day
  2. #2 Re: 2001 GTP w/ 213,000 miles and counting
    good to see that car still running along like a champ.
  3. #3 Re: 2001 GTP w/ 213,000 miles and counting
    GTP Level Member SuperSport's Avatar
    Michigan
    Post pics of the car!
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: 2001 GTP w/ 213,000 miles and counting
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    nice. i just rolled 165k a couple days ago.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  5. #5 Re: 2001 GTP w/ 213,000 miles and counting
    SE Level Member NashGT02's Avatar
    Davenport, IA
    Nice to see its still running strong. As for the Seafoam it may run a little rough depending on how bad your lines and chambers are because it will clean them and also if its been awhile maybe run a can in the next tank to make sure you get it nice and clean and use 93 octane if you have it available.
  6. #6 Re: 2001 GTP w/ 213,000 miles and counting
    Texas
    Very nice and we need some pics for sure! I'm only at at 185k, but mine is still going strong. These engines last forever when treated right and maintenance is kept up on them.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: 2001 GTP w/ 213,000 miles and counting
    good to know another 3800 sc has passed 200,000. im up to 213,00 my self, i don't really beat on it much either, but the yesterday some twit was driving like a lost person and f'in up the whole flow, so they half assed pulled to the side and i went to pass them, as im side by side they start driving so i nailed while doing like 10 mph and both front wheels broke lose, i was shocked!, i let off and pedaled it and they broke lose again,shocked X 2!,,great cars i tell ya.
  8. #8 Re: 2001 GTP w/ 213,000 miles and counting
    Tennessee
    Just found this place while looking around. I'm at almost 251,000 miles on my 99 GTP. Bought it new in February 99.
    I was scanning the web for additional resources. just picked up a new harmonic balancer to replace the original one that went bad a few days ago. It has been a great car.
  1. 2001 GTP Trans into 2001 SE?
    By TechSmurf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 07:11 PM
  2. 6,821 And Counting.......
    Last Post: 12-11-2008, 05:14 AM
