Thread: HELP!! My GP died on the interstate after overheating!!
Results 1 to 20 of 26
  1. #1 Re: HELP!! My GP died on the interstate after overheating!!
    Your story is confusing. How does it quickly overheat when you say it only got to 210*?
    Clearly you lost coolant, the question is where. Did you UIM finally crack internally, did you coolant elbow let go, did your hoses leak or pop?
    The extent of the damage is dependent on how far you pushed it overheating it. Steam coming out is a clear sign that it got very hot. You may not have noticed if there wasn't enough coolant in the LIM to show on the temp gauge.
    Fill it up and see how bad it is.
  2. #2 Re: HELP!! My GP died on the interstate after overheating!!
    Grand Rapids, MI
    I checked my plugs, wires, fluids this morning and everything appeared okay. No hoses broken or anything.
    I got it to crank up and it sounds awful. It's a knocking sound coming from the engine. And it sounded at first like the belt was squelching or something.
    Anyways, I made two vids. I apologize for the footage but I was focused on you guys hearing the sound. Pay attention to it running and that knocking sound.
    In the first video, the first part sounds like the alternator or something I'm not sure. But then around 13 seconds and at 20 seconds you can really hear the knocking sound.
    Here it is:
    And the second video is more of the overall sound not up close:
    Please guys if you have any clue what's going on just chime in. Thanks a lot
  3. #3 Re: HELP!! My GP died on the interstate after overheating!!
    Donating Users Rust's Avatar
    Jun 2010
    Canada
    I think I remember you just getting this car. How did the oil look when you first changed it? Does it look okay now? How is oil pressure? Still not throwing any codes? Any extra smoke or liquid from the exhaust? Have you let the car idle long enough to warm up and get the coolant flowing again? Even compression in all cylinders? Plugs all firing? Did the car shudder and jump when you gave it gas or just bog down?
    Pull of the valve covers and have a look. Maybe a busted spring or lifter failure. Keep an eye out for ANY coolant loss. Could be UIM or LIM gasket failure which caused overheating and fried a bearing.
    No codes, clean oil, and no loss of coolant are good signs that it may be a reasonable fix.
    I have no answers but the experts will probably speak up soon. Good luck.
  4. #4 Re: HELP!! My GP died on the interstate after overheating!!
    Grand Rapids, MI
    Quote Originally Posted by Rust View Post
    thank you for that! yes, i did just get it i've been driving it everyday for a month with no problems. it does leak coolant but its just a tiny spot through the radiator that i will fix later down the road. i didn't run it long this morning i was so scared something would mess up because of how bad it sounds.
    from what i gathered this morning it would still idle up it was just really rough.
    the oil each and every time during and after the LIM change was acceptable and clean. i mean, last night i didn't even let it get hot enough to overheat before i pulled it off the road but it died due to missing pretty bad.
    im really leaning towards a busted spring or lifter failure because it kicked down and the engine roared and as soon as that happened it just went to crap. started heating up and steaming and losing power.
    its not even smoking at all, so does that 100% rule out head gasket?
    ill have my dad check under the valve covers i think thats a good start.
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. 2004 Grand Prix GTP Overheats
    By GTP4JR in forum General Tech Discussion
    Last Post: 06-06-2010, 08:22 PM
  3. Car Dies
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 04:14 PM
  4. HELP! Overheats at idle
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 11-03-2009, 04:30 PM
  5. Engine overheats, heater blows cool air, leak by egr tube
    By twillroth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-30-2009, 03:13 PM
