Thread: Car wont start... starter issue
Results 1 to 10 of 10
  1. #1 Car wont start... starter issue
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    alright parked my car the night before... go out the next morning to leave... turn the key and it just clicks once... couldnt tell where the click was coming from... wouldnt jump so i figured its the starter that is the issue... went and got a rebuilt starter that they showed me worked when i picked it up... get it home put it in... connect everything back up... go to turn the key... and just a single click again this time i know it for a fact was from the starter... i need a lil help here cuz im lost so im getting ready to go check all the wires to the starter and make sure they are getting power... other than that i dont have a clue... quick help would be greatly appreciated!!!
  2. #2 Re: Car wont start... starter issue
    Outer Space
    You tried jumping it off to rule out bad battery yet?
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Car wont start... starter issue
    Cincinnati, Ohio
    Quote Originally Posted by Piggy View Post
    and it has a full charge... so def not bad battery
  4. #4 Re: Car wont start... starter issue
    Nov 2008
    Chicago
    I had almost the same issue when I had my trans replaced. It turned out to be corrosion on the starter connections
    97 GTP Sedan: 3" from the downpipe to the mufflers, no cat, ADR 17's, AGX/Eibach, HAI w/k&n, 6k HID's
  5. #5 Re: Car wont start... starter issue
    Cincinnati, Ohio
    well its a new starter on there and connections seem to be good... cuz even just touching the meter to the stud where the 4 gauge power wire connects is good... what exactly is the purple wire for? im assuming its a ground cuz there is not much power to that smaller stud for the purple wire nor the wire that connects the solenoid to the starter...
  6. #6 Re: Car wont start... starter issue
    Cincinnati, Ohio
    nothing?
  7. #7 Re: Car wont start... starter issue
    Akron Ohio
    im having the same problem, new starter, Im lost
  8. #8 Re: Car wont start... starter issue
    Cincinnati, Ohio
    help?
  9. #9 Re: Car wont start... starter issue
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    if your starter is same as the 2003's and down then the small purple wire on solenoid is the S terminal which passes 12 volts to solenoid only when the key is turned to crank the engine. test it any way you can while a helper turns the key. also use a screw driver to touch the small purple wire stud and the other stud with the positive battery wire on it to see if starter cranks engine. careful you dont touch it with the wire that goes from other stud to the starter motor cause thats a ground. if it cranks then current is not getting to ignition or current aint getting past it. if it doesnt crank engine, then that means bad ground at transmission where the wire connects or at battery or starter housing. hope this helps
  10. #10 Re: Car wont start... starter issue
    Akron Ohio
    Mine was a bad starter, Ihad to try two before I got a good one
  1. 97' GP GT wont start
    By AREED in forum Introductions/Noob Questions
    Last Post: 08-16-2010, 06:28 PM
  2. Wont start
    By EmEaston24 in forum General Tech Discussion
    Last Post: 08-27-2009, 09:20 AM
  3. Taking a few seconds to start? Starter the problem?
    By Z28 in forum General Tech Discussion
    Last Post: 03-27-2009, 11:09 AM
  4. car wont start right away .
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 02-15-2009, 01:40 PM
  5. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
